diff ratio and 4wd ability
  • 2002tiiguy
    • Jul 2013
    • 467
    correct me if i am wrong, but wouldnt an ix with 4.10's be able to put more torque to the front wheels if the backs were slipping and visa versa?
  • spdracrm3
    • Sep 2009
    • 959
    Torque split is preset but sun gears in the t-case, and remains the same no matter what final drive ratios are.
    Everyone mis-understands thinking/reading that the torque changes ,it does not, only thing that changes is lockup via the viscous coupling . Torque split is always 60/40 as set by the sun gears
    Sent from my SM-G360V using Tapatalk
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • spdracrm3
      • Sep 2009
      • 959
      4.10 will accelerate faster with higher engine revs at high speeds ,vs slower accel with 3.91/3.73/3.64 lower revs....
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • 2002tiiguy
        • Jul 2013
        • 467
        but, lets say the viscous coupling can transmit 150 ft lbs of torque, thats 150 ft lbs to either the front or rear, multiplied by the differential ratio, therefore the 4.10 ratio differential would have more torque available correct?
        • The Dark Side of Will
          • Jun 2010
          • 2796
          If you're simply talking about ftlbs to the front axle, yes.
          Are you going to enter a FWD racing class?
            • 34839
            the VC doesn't really "transmit" torque. It essentially locks the front/rear output shaft speeds together so that one end can't spin faster than the other end. it's not possible for more torque to be sent to one end or the other than what the planetary gears are set to.
            But yes, whatever the 40% split to the front ends up being, having a higher multiplication from the 4.10 will result in more being put down. Personally, I'm a fan of shorter gears and a higher redline..
            • ndfspd67
              • Sep 2013
              • 111
              Shorter gears and higher redline, my kind of man right there haha
                • Jun 2010
                • 2796
                The VC absolutely transmits torque, but it does so on the basis of speed *difference*.
                Example: If the rear tires were on ice and had zero traction while the front tires were on dry pavement... the rear tires will start to spin while the front tires won't. This will create a speed difference across the VC which causes it to transmit torque from the rear output of the T-case up to the front output.
                  • 34839
                  yes, but it's in an indirect way. it can't for example transmit all of the torque that was sent to the rear wheels - the front wheels still only get 40%.
                    • Jun 2010
                    • 2796
                    Absolutely it can transmit all of one end's torque to the other end. How do you think these cars can move with no front driveshaft?
                    (Or drive the front wheels with the rear on ice in my example above)
                    • 2002tiiguy
                      • Jul 2013
                      • 467
                      ^^ this is what i was talking about, actual numbers, not percentages and personally i am as well, but i already have one screamer 74 2002tii 70mph @4k approx
                        • Jun 2010
                        • 2796
                        Lol. What are you doing with this car?
                        40% is only relevant when the rear wheels have traction.
                        • 2002tiiguy
                          • Jul 2013
                          • 467
                          what am i doing with which car?
                            • Jun 2010
                            • 2796
                            The subject of this thread.
                            • ACVC325ix
                              • Dec 2016
                              • 123
                              So noob mechanical engineering question, but is a higher ratio diff always better then?
                              I have a manual but should I be looking to throw the 4.1 from an auto on there instead of rebuilding the 3.9?
                              Is there any scenario where a lower ratio diff is preferable?
