Stock IX flywheel weight?
  • CrazyPrime
    • Jun 2014
    • 286
    Does the IX have a heavier flywheel then a 325i? what is the stock weight on a IX flywheel?
  • Kershaw
    • 11822
    No it doesn't. A bit over 18lbs.
    AWD > RWD
    • CrazyPrime
      • Jun 2014
      • 286
      Hmm ok the reason I ask is I recently took my flywheel to get lightened and I told them that it should come out at about 13ish lbs when I got my flywheel back it looks like they took some material off the back but it weighs 19lbs. On a normal person weight scale. I'm confused how can it weigh more then it was stock? After they lightened it.
      Sent from my E6653 using Tapatalk
      • Kershaw
        • 11822
        I have no idea. Mine was either 18.1 or 18.8lbs (can't remember) when I took it off the car and replaced it with a JB Racing 8.5lb wheel.
        Mine's an 88, I wonder if other years got the heavier dual mass flywheel.
        Edit:
        https://www.turnermotorsport.com/p-1...th-m20-engine/
        It looks like the dual mass flywheels did come stock on ixs. Weren't they 30lbs? So they removed quite a bit, but it looks like you just wasted a bunch of money. I'll sell you my single mass flywheel for $100+shipping, haha.
        AWD > RWD
        • CrazyPrime
          • Jun 2014
          • 286
          Edit:
          $50 and you have a deal :)
            • 34827
            the scale is probably wrong. the ix flywheel is the same as the RWD cars. I had mine shaved down to about 15lbs. it wouldn't be surprising if a bathroom scale is off by 5+lbs.
            and no, dual mass flywheels did not come on the ix. you can't shave material off a dual mass flywheel or machine it either. What's pictured in that link isn't even a dual mass flywheel - DMS have built in springs and are much heavier. That's a regular single mass.
