Transmission to TC issue
  • CrazyPrime
    • Jun 2014
    • 286
    So I just got my engine in and after I bolted my TC to the transmission I went to put the nuts on the studs that come out of the back of the transmission. When I spin the drive part that connect the output of the transmission to the input of the TC it spins freely with the transmission in neutral. When I tighten the drive nuts to connect the rotating part from the transmission to the TC, it get hard to spin in neutral and it won't go into a gear. So after I tighten 1 of the 3 and try to spin it and tighten the other 2 I can't spin it withheld transmission in neutral.
    Sent from my E6653 using Tapatalk
  • CrazyPrime
    • Jun 2014
    • 286
    when I tighten these.
    • CrazyPrime
      • Jun 2014
      • 286
      • AndrewBird
        The Mad Scientist
        • 11898
        Uh... you're missing the flex disk. There is supposed to be a big rubber donut between the flanges. Without it, the bolts would pull the flanges towards each other and put side load on the bearings. Not good.
        #1 as seen here:
        http://www.realoem.com/bmw/enUS/show...diagId=27_0003
          • 34844
          yes, you need the flex disk and 3 more bolts.
          • CrazyPrime
            • Jun 2014
            • 286
            Mother Of god I'm a idiot. its been a year since my car was out of commission just slipped my mind. I love rev thanks guys!
            • flyboyx
              • 8371
              oy!
              Gigitty Gigitty!!!!
