Anyone run these? BBS RZ 15x7 et20
  • bluebmw.com
    • Oct 2015
    • 180
    There are some e30s running around with these wheels, but I haven't seen them on an iX. Anyone have photos and/or experience?
    The RZ is like a Euroweave or iX weave, but have a convex face, giving an illusion of more lip/width. The width of 7" and offset of 20 seems reasonable on an iX, so I'd be surprised if nobody has tried it.
    Edit: It's technically called the RZ378 and was apparently an optional wheel for the E30.
    • 34827
    ET20 is too low. They might fit with a 195, but they will rub badly with a 205/55.
    • bluebmw.com
      • Oct 2015
      • 180
      Update: I bought a set and will be test fitting them with 205/50 Yokohama S.Drives. I'll post photos and fitment results.
      • Kershaw
        • 11822
        Loool
        AWD > RWD
        • bluebmw.com
          • Oct 2015
          • 180
          Originally posted by Kershaw
          Loool
          What?
          • Kershaw
            • 11822
            Nando told you. You didn't listen. I was laughing.
            I slightly rub the sidewall with 205s on 15x7et25. I can't imagine making it 5mm worse.
            AWD > RWD
            • notanawdix80
              • Apr 2017
              • 111
              Sub'd for info and pics.
              I'd like to test style 5 et24 in my iX. IX style fives dont exist where i live :rippedoff:
              • Kershaw
                • 11822
                It will rub. Can you have the back face machined down 3mm?
                AWD > RWD
                • bluebmw.com
                  • Oct 2015
                  • 180
                  I'm a bit of a wheel hoarder, so I bought these to refurbish for hobby. If they don't work on the iX, no worries, I can put them on one of my other 4x100 BMWs with more clearance. The wheels were local and I already have spare 205/50 tires, so the barrier to entry was pretty low. Not like I ordered new tires online and had the wheels shipped from Russia!
                  Good data point. Are you running 205/55 or 205/50? Sometimes the balloon effect of the taller 55 or 60 series will bulge out more, causing rubbing.
                  That's a possibility!
                  If there's one thing I've learned from internet car forums, it's that you have to take every piece of advice with a grain of salt, especially when it comes to wheel fitment. One man's "too tight" is another man's "perfect fitment."
                  Every car has minor variations from 25+ years of use, in addition to individual tire variations. I know of stock cars that rub on one fender but not the other. Different brands of the "same" size tire, like a 205, have variations sometimes greater than 205s VS 215s of the same brand.
                  Everyone told me that I couldn't fit 15x7 et12 Alpinas under the stock fenders of my BMW 2002, but guess what I went and did? A little test fitting and determination goes a long way. Maybe I'll just have to go the VW route and stretch some 165s over these bad boys. ;)
                  Jokes aside, I will definitely post progress photos as I clean them up, mount tires, and test fit.
                    • 34827
                    205/55 is the stock size - 205/50 is a little undersized.
                    it *might* not rub too badly with a stock ride height, but it's going to look goofy - the smaller profile will increase wheel gap over the already substantial stock gap, and at the same time they are going to poke out even more than the ET25 wheels do (which is already pretty substantial).
                    Additionally, rubbing in the rear is basically unavoidable even with a smaller tire - it doesn't even rub on the fender lip, it will rub up inside the fender well where you can't make any modifications for more clearance.
                    • bluebmw.com
                      • Oct 2015
                      • 180
                      Thanks for the insight. My particular iX is lowered pretty significantly and has more camber than most, so that will play a part in this equation as well. Are you saying that the rear will most likely be more of an issue than the front?
                      • c0rbin9
                        • Dec 2015
                        • 609
                        In for updates. I just bought a set of these from Poland.
                        Site note: I like the color of the wheels in the OP. Are those the original color? Is that a BBS color or a BMW color? Is it one and the same?
                        1991 318is Brillantrot daily driver (slow restoration)
                          • 34827
                          yes, most likely - although you will probably rub the fender liners up front at full lock, in the rear it will likely rub on the body no matter what you do.
                          • bluebmw.com
                            • Oct 2015
                            • 180
                            Not my photo, but it looks like the original BBS silver color. I don't believe there's a separate BMW color.
                            • Kershaw
                              • 11822
                              I run 205/50. I rub on both sides in the rear with hard cornering. Not bad enough for me to do anything about it, it just scuffs the tire. But add 5mm? Then I'd have a problem.
                              AWD > RWD
