Passenger axle leaking oil from oil pan?
  • kidneylover
    • Aug 2014
    • 51
    I rebooted by passenger front axle a couple months ago. When I went to place the axle back into the diff through the oil pan I used a little oil on the splines to help it slide in place. Couple months later I have noticed clean, what I believe to be oil, creating a lil drip where the oil pan meets the axle. Any thoughts where this leak is from. Can it be from the front diff? Any help? thanks
  • Eskie
    • Dec 2014
    • 162
    Is it leaking out of this? There is an oring (#4) that can leak
    Does the oil leaking smell like gear oil?
    • kidneylover
      • Aug 2014
      • 51
      Yes that is exactly where it's leaking from. So it's the inside o ring leaking? Should I not drive the car. I will have to smell it but it feels like oil. Where would the oil come from? Thanks
      • e30davie
        • Apr 2016
        • 1788
        How bad is the leak?
        Depends how bad it is as to how much oil is left.
        • Eskie
          • Dec 2014
          • 162
          That oring seals the tube that the passenger side axle shaft is in. The "tube" goes through the oil pan and holds some of the gear oil that the front diff uses. So that's what is leaking out.
          It really depends on how bad the leak is. If it's a slow drip I wouldn't sweat it as long as you check your front diff oil.
          Replacement of the oring is pretty simple..just take the pass side axle out and unbolt the housing pictured in the post above. Replace the oring and top up front diff oil.
          • kidneylover
            • Aug 2014
            • 51
            Its a small leak. But I hate having my cars leak. Will replace soon as I get a chance then. Should I replace the other seals too would they be simple to take out? Putting that axle in is a pain lol Thanks do. Winter is coming lol
            • The Dark Side of Will
              • Jun 2010
              • 2796
              There's a second identical o-ring where the diff snout seals to the oil pan.
              • kidneylover
                • Aug 2014
                • 51
                Is replacing the bearing and shaft seal inside the housing hard? Anyone ever do it?
                  • 34830
                  There is no way for engine oil to leak through the drivetrain - FYI. Not unless the oil pan is damaged somehow.
