Next up: new gas tank
  • ACVC325ix
    • Dec 2016
    • 123
    Next project is dropping and replacing the fuel tank which decided so spring a massive leak over the past week.
    I already plan on replacing all rubber hoses including the vent hose while its down...Anything else y'all recommend me inspecting replacing while I have the exhaust dropped and rear driveshaft out?
    Cheers!
  • Kershaw
    • 11822
    Inspect everything rubber under your car.
    AWD > RWD
    • The Dark Side of Will
      • Jun 2010
      • 2796
      You have to take the rear driveshaft out, so good opportunity to replace that guibo if you haven't recently.
      Also all the exhaust hangers will need attention.
      • D.Martijn
        • Sep 2016
        • 1024
        What about the steel fuel lines, are they rusty? If so, replace those too.
        When you buy them from BMW they come pre bend.
        Also while replacing those, replace the little phillips screws that hold the fuel lines to the floor with some stainless steel hex screws. If you'll ever have to remove the fuel lines again you won't strip the head on them.
        1990 325iX Touring - November 2018 R3V Car Of The Month
        1980 Volkswagen Golf mk1 1.1
        1974 BMW 2002 Touring
        Instagram
        • ACVC325ix
          • Dec 2016
          • 123
          all solid suggestions, thanks!!
          • 101
            • Jul 2011
            • 764
            +1 for everything rubber under the car.
            Also check the cloth braided rubber line between the fuel tank and the expansion tank.
            Finally, check the rear brake hard lines. They are a bitch to do, but the job is somewhat easier with the fuel tank out. Check the rear brake soft lines between the body and the subframe.
            101
            The E30 collection:
            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
            1987 325is - Delphin / Black Sport (son #3's)
            1987 325i Convertible - Triple Black
            1989 325iX Coupe - Diamondschwarz / Black Comfort
            1990 325iX Coupe - Sterling Silver / Grey Sport
            1981 Fiat 124 Spider 2000 - Green / Tan
            1998 Volvo V70 GLT - White / Tan
            1998 Volvo S70 T5 manual - White / Taupe
            2001 Ford Windstar - Silver / Grey (parts hauler)
            2006 Lexus GX470 - White / Tan (tow rig)
