ix GC camber plates
  • fresh_TD
    • Aug 2013
    • 2457
    ix GC camber plates
    Can the GC ix camber plates be used with h&r springs/ koni shocks?
    Sent from my Pixel XL using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • EyExR
    • Jan 2011
    • 959
    Unfortunately, no.
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • fresh_TD
      • Aug 2013
      • 2457
      Originally posted by EyExR
      Unfortunately, no.
      Is it the OD of the springs?
      • Kershaw
        • 11822
        The height adjuster kit can drop onto the stock strut without welding or modifying though. I paid $850, there is a discount when ordering together.
        I'm sure you could make an adapter if you have a welder, a drill press, and the motivation.
        AWD > RWD
        • fresh_TD
          • Aug 2013
          • 2457
          So the adjusters would work with stock housings and H&R springs, but not the camber plates?
            • 34839
            yeah, it's just that there's no spring perch that fits stock springs.
            and really, I don't think I would use them with H&Rs anyway. They increase the stack height, which reduces suspension travel - and H&Rs barely have enough travel as it is. On top of that, it's basically a solid block - there's no give, so you'd be bottoming out constantly and have a lot higher NVH. Not a great combo.
            FWIW the build quality on these is awesome. But I'm not sure they are suited to a DD, although I did on mine for a long time..
