Clanking noise in the front
  • 1990m3
    • 1180
    Unfortunately it's bee a busy winter and I haven't had time to get underneath and diagnose my problem, anyone have any ideas?
    THe front drivers corner clanks a lot when I'm driving down the road or going over bumps, doesn't really seem to matter if the road is smooth or not. Also, above 40mph there is a vibration under hard braking.
    The steering feels good so without looking I would be inclined to think it's not a tie rod end which leaves me to an upper shock mount, sway bar link, or control arm. The clanking almost feels like it's coming from under my dead pedal...this is most likely a control arm balljoint, right?
    Any other similar experiences? I'll look at it tomorrow night after work and try to see for sure.
    • 34847
    ball joints, CABs, upper strut mounts come to mind.
    jack up the car and see what you can move around - when my ball joints went out, I could move the front wheels quite a bit.
    • 1990m3
      • 1180
      jacked it up, everything felt tight, guess i'll have to look a little closer at all the bushings
      • kellie
        • 702
        Can you duplicate it by having someone jounce the car while you try to pinpoint the noise?
        • 1990m3
          • 1180
          don't think so, I tried that yesterday.
          how long do control arms last? the car has had an easy life on florida streets and only has 89k, I have to look at it closely this weekend, but I'm hoping it's a tie rod end or control arm bushing...cheap and easy! I just realized those control arms cost $257.00 each!!
            • 34847
            the inner ball joints last forever, the outters do not - however, the outters are replaceable seperately for about $50.
            • aaron325ix
              • Jun 2007
              • 1489
              I had a very similar problem, but all my stuff had been replaced everything befor that(tie rods, CA's CAB's) My mechanic couldnt even figure it out for a while. Finally figured out it was my steering rack starting to take a shit. When you brake the toe changes and the loose rods in there are banging around. At least that is the way he explained it. It was doing it over very small bumps in the road too, kind of a knocking. just a thought.
                • 34847
                I doubt it with only 89k, but who knows. I think that would be noticeable in the steering though with more play.
                • aaron325ix
                  • Jun 2007
                  • 1489
                  I could not "feel" any difference either, just a knocking. Actually after reading it again, the symptoms are almost exactly to what I was having. Although 89k is pretty low, but who knows.
                  • 1990m3
                    • 1180
                    Where can I order the outer ball joints from? Also, can i use m3 offest bushings for the control arms or are they iX specific. I have a set of offset bushings in the carriers sitting in my toolbox, it would make for a quick swap.
                    • kellie
                      • 702
                      My friend has the M3 bushings in his iX and loves them.
                        • 34847
                        yeah, they work great actually. give it a shot since you already have them.
                        as far as where to get the parts, you should be able to order them almost anywhere over the phone - I don't know who lists them on a website though.
