Im looking at buying an iX that has a clean rust free body, BUT it seems like it needs a major valve adjustment. My question for you guys is basically, does this motor have a tendency to be very noisy? Could it be the timing belt or water pump?
A small but potentially big issue.
Change the timing belt, adjust the valves, and run an oil additive then if its still loud you have problems.
1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
Originally posted by kenika65 View PostChange the timing belt, adjust the valves, and run an oil additive then if its still loud you have problems.
Originally posted by Mclassy View PostYeah I actually had plans of doing the first two once in my possession. Ill try the oil additive as well. My signs are pointing to the timing being massively off.
Pull the valve cover off and look carefully at the camshaft. Look for grooves where the rocker arm pad rides on the cam. If you see a big freeking trench, the thing needs a new cam and likely as not a fresh head.
This would be good ammunition to beat them down on the price...
