need some quick help from informed iXers
  • yoni
    • 468
    hey guys,
    just need to know if the front sway bar links are iX specific..
    or can i get any e30 ones?
    same thing with tie rods.. also, i checked a couple places, and i have only been able to find the whole tie rod, nut just the inner.... is that just how it is ?
    same question for front top plates (strut mounts..), iX specific?
    THANK YOU!
  • yoni
    • 468
    no one knows...?
    nando..?
    • yoni
      • 468
      someone should know...
      i'm about to spend a lot on "iX specific" shit..
        • 34844
        yes they are ix specific
        • Alkasquawlik
          • 4557
          theyre iX specific, due to the front drive shaft iirc
          SC*AR
          Originally posted by JamesE30
          And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
            • 34844
            uh, I guess. You could say the engine harness is ix specific due to the front driveshaft as well, but that's not very accurate or clear. ;)
            • supernaughtIX
              • Apr 2007
              • 260
              ok, due to the front axles the steering rack is mounted differently, and the tierods have a wicked bend to them so they clear the axles and attach to the strut housing differently. also due to the axles, the bottom of the strut insert is higher, and so BMW used special strut mounts with lots of flex and more overall height.
              Because the strut housings are different, the sway bar links are different too. Check out the differences on www.realoem.com
              It does suck, but must be done.
              Also the control arms are different and can be a headache if you find a damaged inner balljoint. But there are a couple sources out there. I just bought one last week.
              88 325 IX DiamantSchwarz - TOURING - waiting...
              89 325 IX AlpinWeiß - Gone
              88 325 IX DiamantSchwarz - Parted
              89 325 IX RoyalBlau - Parted
              88 325 IX RoyalBlau - Gone
              • Autobahn Sport
                • Apr 2008
                • 411
                iirc, M3's use the same endlinks.
                Autobahn Sport - ***503.715.0044*** - "ABS BMW Parts" on AIM
                **To avoid delays with shipments, please note which parts you are paying for AND YOUR R3VLIMITED USERNAME in the "note to seller" field when using PayPal**
                • supernaughtIX
                  • Apr 2007
                  • 260
                  Endlinks are a little different
                  IX
                  http://www.realoem.com/bmw/showparts...44&hg=31&fg=10
                  M3
                  http://www.realoem.com/bmw/showparts...41&hg=31&fg=10
                  • Autobahn Sport
                    • Apr 2008
                    • 411
                    Originally posted by Fidhle007
                    Ooh snap. NOT something you want to hear from a shop...
                    BTW, they are different, sry. It is still early here, still on coffee numero uno.
                      • 34844
                      nope, they are similar but M3 links are a little shorter and one end is turned 180 degrees from the ix.
                      but that just means adjustable endlinks from an M3 are a nice fit for us ix guys. they've also been cheaper than OEM most of the time, depending on where the dollar/euro conversion is...
                      • Autobahn Sport
                        • Apr 2008
                        • 411
                        Thanks for the clarification. :D
                        • Need4Speed1299
                          • Oct 2007
                          • 119
                          I bought a set of new links off bavauto for $47. Im new to the IX, would it be correct to assume these go bad often?
                          • Fidhle007
                            I can fly, motherfucker
                            • Oct 2005
                            • 7209
                            Probably more often than those of a rwd E30 but no more than anything else with a similar design, like most newer BMWs. They're just wear parts like any other suspension component.
                            '89 325is S50 Track Montser
                            '04 X5 Daily/Tow Vehicle
                            http://www.avarestoration.com
                            http://www.myspace.com/brendanfiddle
                            Click here if you want to be my zombie slave...
                            http://www.youtube.com/user/Fidhle007
                              • 34844
                              I don't think so, but I'm thinking 90% of ix's out there have never had them (or many other suspension parts) replaced yet.
