order of drivetrain in iX
  • flyboyx
    • 8371
    #46
    Originally posted by nando
    well they designed an all new suspension and made a special mold for the aluminum front subframe, so what's a different bolt pattern?
    also, something that hasn't been suggested yet -the bolt pattern is the same on both transmissions, but the ix transmission is rotated 10 degrees. The ix tranny uses an entirely different mount, shifter carrier, lever, etc. so that's entirely possible. Either way, the ix M20 doesn't sit in the same position as other E30s.
    i think some of you are making this more difficult in theory than reality dictates. actually, the 24v engine is what has the bolt pattern indexed 10 degrees. the modified e30 ix oil pan will sit in the right "level" position for the front drive shaft. this is the reason why the engine needs to be rotated 10 degrees to the driver side. everything of the drive train will sit in the proper position. seriously, even if you can't visualize it, just trust me. the biggest problem is figuring out what to do with the brake booster. the best solution (in my opinion) is to add e23 hydroboost so the intake manifold of the 24v engine will clear. i am in the middle of an s52 swap that i am documenting in the 24v section of this forum. there is quite a bit if info about this on there. an added benefit is that you get a larger diameter master cylinder for better braking force. my car is a vert and not an ix. however, i have something up my sleeve related to ix's that will be also documented on r3v when i finish with this project.
    no, i haven't done the swap yet, but i have done a lot(emphasize the word "lot") of reaserch and i have all the parts to get started when i get time.
    another problem is that 3.91(manual) or 4.11(auto) ratios are not very well suited to the torque a 24v engine will produce.
    don't waste your time dreaming about euro 525ix oil pans and transfer cases. i have been there. it has been documented that the oil pan won't work because it conficts with the e30 crossmember. the pan to diff bolt pattern on the 525 allrad is different than the e30 ix diff as well. also the axle ratio of the 525ix is an oddball. if memory serves me, i am thinking 3.38. you will certainly need to match it to the rear. the only thing imported in the united states with that ratio is an auto m3. who knows if you can take the ring and pinion from an e36 and put it in an e30 case.
    your best(probably only) choice to adjust the ratio would be to get your hands on a set of factory euro 3.64 final drives unless you have the funds to get a custom ratio cut for the front. i am thinking about getting a 3.25 ring and pinion made for my front.
    the info is out there on the other forum. it will just take some effort to find it in a search. i think it is just a matter of getting the info out an distributed to those of you that are interested so that swaps will get done.
    Gigitty Gigitty!!!!
    • moatilliatta
      • 6151
      #47
      or a short runner intake could be used to clear the brake booster. I was thinking of some type of itb set up, but with that you would most likely have to run the hydroboost set up.
      @Zakspeed_US
      • Eric
        • 5142
        #48
        got any pictures of the clearance problem?
        • 87e30
          • Jul 2008
          • 5676
          #49
          flyboyx, did you ever make this happen?
          I just hate everyone.
          No need for discretion.
