clutch pedal - same as RWD e30???
  • beamR X
    • Apr 2006
    • 145
    My question is: is the iX clutch pedal assembly the same as any E30?
    Here is the story:
    So I spent the whole evening trying to bleed my clutch and the pedal just refused to react to any attempts to bleed.
    I was like WTF!?!?!?
    So I started to inspect the whole system regardless of how unlikely and sure enough: the most unlikely of all: the actual plastic pedal assembly is broken at the base of the pivot. It's just snapped! I am very unhappy about it as it happened at the body shop they were doing some frame tweaking.
    The car had a bad release bearing so when it quit on them at the shop I kind of felt bad that it caused them inconvenience, but no I completely reversed how I feel. Some yard monkey broke the pedal not knowing what he was doing and everyone just assumed it was the bearing....
    closeup:
    Anyways.I'll be probably trying to find a used one at the bone yard and want to make sure the RWD pedals aren't any different for whatever odd iX reason...
    PS: I think my clutch is cursed...
    (.Y.) R cool.
    Falco rocks!
    • 34839
    ew, your car has one of those plastic pedals...
    I don't beleive it is ix specific. However, the pedals are specific to airbag/non-airbag cars. I'd suggest looking for a new pedal, made out of steel so it won't break :)
    • beamR X
      • Apr 2006
      • 145
      Thanx nando.
      Will the metal pedal bolt in in place of the plastic no problem or will it not work as in : the brake pedal is also different and I need both?
      (.Y.) R cool.
      Falco rocks!
        • 34839
        it should work, but honestly I'd probably get both, wouldn't want your brake pedal to break next! :o
        • beamR X
          • Apr 2006
          • 145
          No kidding, but note that the brake pedal in my car IS metal.
          It's just clutch that's plastic...
          (.Y.) R cool.
          Falco rocks!
          • 2002maniac
            • 4260
            just make sure it's from a non-airbag car.
