iX oil filter change
  • Alkasquawlik
    • 4557
    I CANNOT for the life of me figure out how to take the oil filter off.
    I tried turning it by hand, but i cant get a solid enough grip on it to turn it.
    I used an oil filter wrench, but I couldn't get enough space under there to move it. It would get stuck between the headers or the front diff.
    It's really frustrating me as I know the oil filter is a significant part to a proper oil change but I can't get it off.
    any of you iX guys have any tricks or tips?
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    Same as any other filter, twist it off. Go buy yourself a set of oil filter pliers though, that should improve things for now and when you put the new filter on don't over tighten it this time
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • Alkasquawlik
      • 4557
      The thing is I can't twist it off. Like I said, by hand, it's too greasy to get a firm hold, and with the oil filter wrench I don't have room to turn it.
      I've never switched the oil filter myself on my iX, it's the PO who over tightened it and fucked me.
      I'll look into the pliers though.
      SC*AR
      • xwill112x
        • Jan 2009
        • 4236
        hammer a screw driver through it. then smack the screw driver with a hammer.
        that should do it, its what i do on my mom's explorer every oil change.
        • Fidhle007
          • Oct 2005
          • 7209
          Then you're way overtightening them.
          • Holland
            • Nov 2008
            • 7212
            That is usually a last resort. Oil filters should not be that tight. I'm imagining that they are dry gasketed as well?
            Originally posted by DEV0 E30
            • Spinning Tires
              • Feb 2007
              • 283
              maybe something like this from sears. you can put a ratchet and long extension on the bottom if you have to
              First: 1984 318i
              Second: 1987 325
              Third: 1987 325is
              Current: 1990 325i (Soon To Be 335i)
              • Alkasquawlik
                • 4557
                wouldnt you be risking stripping the threads when youre hammering the screwdriver through the filter?
                SC*AR
                • AWDE30
                  • Jul 2006
                  • 762
                  go to any auto parts store and buy a oil filter socket, bring your new filter to make sure it fits, get an extension, hammer on the socket and twist off. i had this same problem with my iX on its first oil change If your skinny enough you can fit under the car without putting it on jack stands.
                  • xwill112x
                    • Jan 2009
                    • 4236
                    no, its just the way that shit pile is, i can turn it 1/4 a turn past hand tightening, 6 months later, that shit will be stuck. i think it's just the explorer, and the way the filter is on the motor.;)
                    • Spinning Tires
                      • Feb 2007
                      • 283
                      your only supposed to hand tighten it
                      First: 1984 318i
                      Second: 1987 325
                      Third: 1987 325is
                        • 34844
                        you need a "cap" style oil filter wrench that goes on the end of a ratchet. they sell them at autoparts stores, I happened to get mine from bavauto. I don't even screw around trying to undo the filter by hand anymore, I always go straight for the tool and have it off in a few seconds.
                        also this really isn't an ix question as there isn't anything about changing the filter that is different from the other E30s. ;)
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          You're overtightening it.
                          • xwill112x
                            • Jan 2009
                            • 4236
                            lol if you say so.;)
                            it's the only one ive ever had problems with.
                            • xwill112x
                              • Jan 2009
                              • 4236
                              and thats more of e30's with m20's,
                              m42's have the drop in filter. ;)
