Control Arm Bushings
  • s_hemphill
    • 64
    Hello,
    Does anyone have any insight into why the control arm bushings on our cars are ix-specific? I'd like to put some e36 (or something beefier than stock) bushings on my car, but I'm starting to have second thoughts after noticing the ix didnt come with run-of-the-mill E30 CABs.
    Thanks
    Steve
  • fresh_TD
    • Aug 2013
    • 2457
    They're not ix specific. I run oe e36 CABs on my ix.
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • D.Martijn
      • Sep 2016
      • 1023
      What Fresh said, bushings aren't ix specific - I use E30 M3 offset bushings myself.
      However, the balljoints are specific!
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • fresh_TD
        • Aug 2013
        • 2457
        Originally posted by D.Martijn
        What Fresh said, bushings aren't ix specific - I use E30 M3 offset bushings myself. However, the balljoints are specific!
        Only the inner ball joint is specific, the outer is the same as rwd e30s.
        • packratbimmer
          • Dec 2009
          • 1332
          The iX has a specific part number for the CAB, but it is nothing special. # 31101130503 is the part number. I think they are a bit stiffer than the stock E30 part from what I have seen. I would use solid centered E36 M3 CABs from a 96+ E36 M3..
          • The Dark Side of Will
            • Jun 2010
            • 2796
            I guess we're talking lollipops *NOT* RTABs, since everyone's using E36 parts...
            • fresh_TD
              • Aug 2013
              • 2457
              You don't have to guess, just read the original post, and every post before yours. The OP clearly stated "control arm bushings". Which has nothing to do with anything in the rear, Pal.
                • Jun 2010
                • 2796
                I'm not your pal, friend.
                A trailing arm is a control arm.
                • s_hemphill
                  • 64
                  Thanks guys.
                  • ixtim
                    • Jan 2020
                    • 1
                    Hey guys, just wanted to check and confirm if there is a parts source for the inner IX specific ball joints. If the inner joint is bad it basically means replacing the entire control arm correct?
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      I have a brand new set of ix control arms, for sale.
                      • D.Martijn
                        • Sep 2016
                        • 1023
                        The inner ball joints which are specific for the iX are available, however only in Europe.
                        I ordered 2 pairs for myself but if you're really desperate I could get a pair from my local dealer if they can still get them.
                        Instagram
