Anyone run Bils HD with stock springs?
  • 2002maniac
    • 4260
    so my front struts are shot. I was just going to buy new Boge all around but the bilstein HD are the same price. Anyone run this setup? any speculation would be welcome as well.
  • supernaughtIX
    • Apr 2007
    • 260
    if they're the same price go for the billies. No problem with stock springs
    88 325 IX DiamantSchwarz - TOURING - waiting...
    89 325 IX AlpinWeiß - Gone
    88 325 IX DiamantSchwarz - Parted
    89 325 IX RoyalBlau - Parted
    88 325 IX RoyalBlau - Gone
    • e34john
      • Apr 2006
      • 3599
      How much were the TCs? TCs are usually about half the price and thats what I would get if I was running stock springs but if there isn't much of a difference HD would be the way to go.
      • lov-e30
        • 16548
        I run HDs at the front with GCcoilovers and rear with e36 M3 springs for the extra weight from my subwoofer box, I like the nearly stock ride with a light drop as I daily my car. ;)
        @IRON-E30 aka Edwin:D
        • Liam
          • 753
          The Bilstein are a little better shock and I prefer the dampening profile over the OE Sachs/Boge.
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
            • 34844
            HDs are a far better design than the stock Boge.. the HDs will probably last 3 times longer too. does anyone really use stock shocks anymore?
            • Jean
              • 18228
              May I ask how the Bilstein Touring inserts compare to HDs ??
              • Liam
                • 753
                A little "softer" dampening is pretty much the only difference.
                • netcsk
                  • Apr 2004
                  • 1609
                  You are supposed to match the damping of the shocks with the spring rate of the springs to obtain optimal road performance (i.e. over/under damped). You can do the calculation, but the HDs will be too stiff to give you the optimal ride for comfort and design. If you're looking for stiff with a stock ride height, then the HDs will work, but they won't be matched correctly in the least bit.
                  • Liam
                    • 753
                    This is partially true, however the HDs on stock springs isn't all that bad of a match (as long as you get the correct application).
                    • Jean
                      • 18228
                      Zing. Exactly why I think my H&R sports aren't exactly matched with the Bilstein Sports :(
                        • 34844
                        what did you think bilstein engineered these things for?
                        • Liam
                          • 753
                          That's one way of putting it ;-).
