Shaved body moldings?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Has anybody shaved the side moldings, and if so any pics? Searching didn't bring anything up, but the thought has crossed my mind since the car is in the process of bodywork now.
    Thanks in advance,
    -John
    john@m20guru.com
    Links:
  • e30nub
    • Jun 2008
    • 1741
    Thanks in advance,
    -John
    I know I've seen a pic somewhere, but it's been a while since I last saw it.
    You should shave the door keys and antenna too and just get a keyless entry system.
    -Pierre
    1987 535is
    1988 325is
    • M-technik-3
      • 18946
      Jordan did it to his car quite some time ago, I'm sure others have as well over the years. It was a common trend in VW world.
      • ForcedFirebird
        • Feb 2007
        • 8300
        Something like this perhaps?...
        I believe it would look more like an M3, but I wouldn't be caught dead re-badging it In fact thinking of dropping the 325es for a cleaner look.
        Thought about it, but I really don't want to eliminate the lock and/or handles. Probably going to have the bumper covers (between the chrome and body) and mirrors painted body color (possibly black mirrors).
        I have time to decide, but really need to get on the ball if I'm going to be doing all that welding :D
        john@m20guru.com
        Links:
        • lifeiskaos
          • 1709
          you'd weld them? interesting...
          • ForcedFirebird
            • Feb 2007
            • 8300
            I wouldn't trust that much filler, would you? Cut strips of sheet metal and weld it in, then grind and fill as little as possible.
            john@m20guru.com
            Links:
            • theox69
              • May 2008
              • 1732
              Here's a job well-done!
              you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
              • ForcedFirebird
                • Feb 2007
                • 8300
                Originally posted by theox69
                Agreed. I actually like that better than eliminating them all together. :D
                I really dislike the chrome.
                Speaking of chrome, also have been thinking about changing the windshield/rear window moldings, but that's later :(
                john@m20guru.com
                Links:
                • e30this
                  • 3580
                  I shaved mine on my first e30 years ago.
                  I welded a piece of metal all the way down the whole door and then used fiberglass filler then bondo.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Nice :)
                    What did you use to keep the body step equal-distant, or when you look close can you see varying depth between the body lines? I definately don't want to taper body filler from the top to the step in the body, must be as much metal as possible...
                    Thanks for the great pic!
                    -John
                    john@m20guru.com
                    Links:
                    • BLK MAGIC
                      • 6
                      The shaved look is always the good look. Id do it!
                      Achieve Rezolution...
                      www.Rezmoto.com
                      "The Leading E-Magazine For The Modified Euro-Auto Community"
