325is Bodywork
  • ortholithiation
    • Dec 2009
    • 181
    325is Bodywork
    I'm going to start to post my progess on my car. I bought this 87 325is for a decent price. Mechanically its pretty good, except for locks, horn and a leaky fuel line.
    I'm pretty new to bodywork, been good with everything else so far, going to dive right into it appreciate any help and advice.
    What I plan to do is.
    1) fix the rust
    2) Shave side moulding and antenna
    3) Prep for paint
    4) Roller paint job (maybe)
    Here is the car
    The rust, god damn cdn roads. Seems mostly in the rear.
    It's nice when the GF can help you scrap the undercoating off. Notice where the shop light hangs :(
    Before you start sanding remove the grease and wax. Take a rag and wipe it down with mineral sprits. Changes rags/shop towels often or you will just end up spreading it around.
    Started sanding, intially with a 400 grit wetsand, but it doesn't really cut into the clear coat that well or evenally. I find a light 220 wet sand really gets all the clear off evenly, and follow it up with a 400 wet sand its also faster. You can really feel like you've stripped off the nasty clear coat and all its impurities. I use a squirt bottle with a drop of dish soap. This helps move the paint and cleans out the oils trapped.
    Sideskirts can be done indoors with TV close by.
    Started to bring the tailights back to life, toothpaste works well.
    Coat of tremclad black on the sideskirts.
    Fill in the chips with glaze.
    Pretty bad gap in the rear
    seems to be rivited onto the bumper? causing the sag?
    After cleaning a load of yellow shit in the trunk, caused by battery gases I'm assuming. Need to finish and flat black it.
    Doesn't the front end remind you of the 69 camaro.
    here is the hood after 220, try to sand in opposite directions to get a cross hatch.
    This part had little cracks, so I sanded it down to the primer then reprimered it back up and feathered the edges.
    Here you see the hood, the part closest is 400 wetsanded and the middle on is 200 you can feel the difference. The flash brings out the scratchs like crazy it doesn't really look like this. Also you can see what the glaze putty looks like after sanding down.
    Need shielding gas, anyone in montreal know where to get it without a liscense, only need a small bottle.
  • Denny
    • Jan 2010
    • 822
    Glad to see another close by canadian brother doing the same thing as I will be doing (waiting to move in my new house in few days...its got a much bigger garage) I will be redoing the whole car inside and out.
    Mine is a 1987 325IS black as well its in not too bad shape passed an Ontario safety in 30 minutes to my surprise everything works on it.
    Right now am being proactive and trying to find good price canadian on Auto paint, primer, clear coat..etc...etc... going to be painting myself its going to be a challenge but am up for it.
    here are some pics.... and the spoiler well am going to burn it... I got a IS spoiler in the mail from a friendly bro in the forum who gave me a good deal. The trunk will be the first to go... :)
    here is my welcome thread...
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • koole30
      • Jan 2010
      • 28
      Ortho,
      You need to finish up your sanding with 800 wet sandpaper. The heavy grit sand paper scratches will show through (especially with silvers or golds). And what ever you do not roll the paint on, go buy an inexpensive gravity feed spray gun. PM me if you have any questions.
      Good Luck.
      • reelop19
        • Jan 2010
        • 770
        If you roll the paint on then future paint jobs are out of the question. I believe most use rustoleum and you will have to sand every bit of that off if the car ever gets a proper paintjob because automotive paint doesn't work well on top of rustoleum.
        • ortholithiation
          • Dec 2009
          • 181
          almost finished up the body with 400 today.
          Yes I am considering just getting it sprayed after all this work, might have a hook up and get to help out :) .
          If I do that, I will be sure block it down with 800 before spraying it. Prep work is key.
          If I do roller it, I would leave it at 400 since there would be a lot more sanding while painting. I know if it gets rustoleum then it can only be painted with rustoleum afterward. I've done lots of and lots of research. I've become a bit of a perfectionist and to tell you the truth I think I will regret the roller paint + 6-7 coats seems like insanity.
          • ortholithiation
            • Dec 2009
            • 181
            Good advice about the 800, finished up the hood, looks a lot better.
            As much as a cheap ass I am, I think I will put the roller idea to rest and just spray it.
            Roller jobs FTL.
            • ck_taft325is
              • Sep 2007
              • 6880
              What are you blocking with exactly?
              Need a part? PM me.
              • Danny
                • 14216
                I would have sex with your gf.
                • craiggroves91
                  • Oct 2009
                  • 3024
                  Lets see how OP takes this comment/compliment/disrespect haha
                  Maybe you should keep those things to your self when it comes to a chicka
                  1989 BMW 325i SOLD
                  1998 BMW Estoril Blue e36 M3/4/5 SOLD
                  1987 BMW 325 (The Piece) SOLD
                  1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                  • Danny
                    • 14216
                    its a compliment.
                    • richardkeith97
                      • 1693
                      u don't gota wet sand everything just DA with a finishing DA wit 800 on it. and a soft pad between the DA and the paper. do the edges with a grey scotch brite pad.
                      • richardkeith97
                        • 1693
                        anyhting that your gona paint and not just clear DA with 400 and a soft pad in between
                        • ortholithiation
                          • Dec 2009
                          • 181
                          Blocking it down = sanding with rubber sanding blocks. Is this the wrong term?
                          In regards to Danny's comment:
                          This is R3V/the interwebz, I'm used to it and take no offence. Thanks, my GF is hot!
                          I'm grateful for a place like this and people to help and I try to listen. The strong support of forums and people was an actual factor in buying an e30. A little bit of fun and poking is never a bad thing, but overly negative comments/humiliation I find to be a bit toxic.
                          The paint is pretty nasty in some places, cracks, rust and poorly applied chip/fix or tremclad by PO. I'm fixing a lot of spots and take it down to the bare metal for welding/bondo it just seems more even if I take off the clear coat and get something clean and even to work with. It seems easier to feather in primer the repaired portions. Maybe I’m wrong here.
                          Sorry I don't know what DA stands for. Body work is kind of new to me and I don’t pretend to know everything but trying to learn.
                          I’ll post some pictures up soon. Might get a good deal on some diamond swartz (sp?) and get to spray it. Your help is always appreciated.
                          • Danny
                            • 14216
                            :up:
                            Thatta boy.
                            • ortholithiation
                              • Dec 2009
                              • 181
                              I've sanded through the paint in a couple of places on the edges. I've tried to mask off the area and reprimer but it's difficult to feather it in without burning through to the metal, no matter what grit I use.
                              TIP ONE: Spray some primer on a little foam brush and dab the affected area, you can even feather it in while painting. Follow it up with light light light 800 grit to smooth and feather it in
