Late model euro plate filler question..
  • bmwm3n528
    • 3654
    Can someone measure where they drilled their US holes are on their filler?
    Would be appreciated.
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
  • screamingbmwe30
    • Jan 2005
    • 415
    mark the white tabs on the car with paint and lay the plate filler against it where it is supposed to go. then look at the rear of the plate filler for the marks and drill 8)
      • 34839
      no measuring, just hold the filler in place, mark from the inside and drill.
      • bmwm3n528
        • 3654
        Alright, yeah...it's easier now that i'm doing it...just thought I might need some measurements.
        Did you guys leave the white tabs?
        Trevor Ely
          • 34839
          I put them on the inside, if you leave them where they are the plate filler will stick out. there's barely enough thread to engage the screws though, might be a better idea to switch to some nuts and bolts.
          • bmwm3n528
            • 3654
            Yeah, I left it...and there was a tiny bit of bulge until I used the who holes on the top of the filler(near the license plate lights) ...that tightened it up nice and snug to the body.
            Thanks for the help.
            Trevor Ely
            • rwh11385
              lance_entities
              • 18403
              Originally posted by rwh11385
              Maybe some more pictures would help:
              Remove that trunk liner, and knock those plastic screw holders out of there!
              Get some nice hardware to secure plate. A flathead bolt, some washers, and some nuts do great.
              Drill a hole for the bolts. Line up to space first and mark before of course.
              Mount. Put bolt through license plate, through filler, through body, then put the washer and nut on, then re-install liner.
              • bmwm3n528
                • 3654
                Sweet, could have used that couple hours ago slacker.
                :D It's cool, I just used the white things and it still looks cool.
                Trevor Ely
                • rwh11385
                  lance_entities
                  • 18403
                  Shit, maybe it I didnt have a hangover and checked this sooner.....
                  • bmwm3n528
                    • 3654
                    :D
                    Trevor Ely
