before I go and drill holes in my trunk...
  • Hatchman
    • Mar 2005
    • 1425
    My paint arrived today and im going to do it tonight but I've got questions about the mounting... whats the best way to get the exact fit so its snug to the corner of the trunk other than just marking and drilling and hopeing it works and what should i do once the holes are drilled, is there anything i should put on the drill holes to prevent rust and or water sepage? couldnt find a DIY or usefull topic... any help please...
    • 34839
    the dealer sells cheap templates for proper alignment. buy one.
      • 37829
      I made a template off an extra trunklid I had and laid it out on my trunk and drilled away. Somehow it turned out perfect
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Hatchman
        • Mar 2005
        • 1425
        I have open access to the car which I took it off of with the holes in it and all
        • Hatchman
          • Mar 2005
          • 1425
          but should i put anything around the drilled holes like rubber washers to prevent leaking or is there some product I could slap on it?
          ive got the stock little ruber paper washer thingers is that good enough?
          • Dave
            E30 RAT
            • 11675
            Was it perfectly mounted on the old one? Make sure. The is Lip on my trunk is not mounted correctly. Prior owner apprently did NOT use a template.
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
              • 34839
              you fuckers are the cheapest bastards on earth! :roll:
                • 37829
                Hey, you act like every other angry R3V member, that's so... original
                Grover Beach, CA
                www.BimmerHeads.com
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  It's worth the few dollars.
                  Originally posted by Gruelius
                    • 34839
                    go drive your car.. oh wait, you can't. :roll:
                    • Hatchman
                      • Mar 2005
                      • 1425
                      It was stock on it.. so i'd think so
                      • Madhatter
                        • Oct 2004
                        • 966
                        you dont need to worry about washers if your spoiler is complete, on the underside there should be a layer of rubber (like matting), it should provide all the sealing you need.
                        Just a little project im working on
                        - http://www.lse30.com -
                        • ToplessE30
                          • 4791
                          Because it's being rebuilt into a 2.7L turbo? If so, sweeeet bash attempt. :roll:
                          Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            It's because he doesn't have a drivers license.
                            • DEV0 E30
                              • Oct 2004
                              • 8880
                              That's Schnieder 325.
                              Matt just tears his apart often to make it better.
