Need help of r3v guru's!
  • alB5
    • 785
    So long story short, got into a crappy fender bender tonight. Some asshole kid in an altima stopped short and you know the rest of the story...
    What can I do to realign the bumper? The bumper shocks didn't do too well of a job which caused my bumper to transit downwards into the valance.
    1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
    No E30 Club
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Wrong kind of bumper to tuck...
    You will probably need a new shock for that side. Where it is sticking out, it has to slide into a another part that is attached to the fender. You should pull your bumper off to see if any thing is broken or if it just poped out. It is just two t55 torx bolts in the bottom of the bumper.
    Also you shouldn't be calling the other kid the asshole when you hit him.
    • alB5
      • 785
      Thanks for the response, i'll need to get some t55 torx heads since I don't think i have any.
      No E30 Club
      • alB5
        • 785
        Do local home depots carry torx heads?
        No E30 Club
        • 10Toes
          • Jan 2008
          • 61222
          Probably or a auto parts store, and they take male torx bit.
          • McGyver
            • 4606
            you can also use an 8mm allen wrench if my memory serves right.
            • 10Toes
              • Jan 2008
              • 61222
              Wouldn't you just use your Victorinox swiss army knife?
              • DrJosh
                • 2011
                Check to make sure yours aren't the Hex instead of the Torx.
                Originally posted by Sonny
                I am a meme for our community.
                • alB5
                  • 785
                  Alright so I got the torx screws out by using an allen wrench but the side just won't budge. I've tried everything, although the other side moves freely.
                  No E30 Club
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Pull harder? Should come out with the bolts removed, but it might be stuck due to rust and/or the crash.
                    • F34R
                      sLaughter
                      • 12376
                      DON'T buy the off brand torx heads. TRUST ME!! I had my set stolen in the yard when I was removing an engine. I also had to remove the bumpers too. So I grabbed a cheap set of them at SEARS(yard was closing) and all they did was strip. Since you know the correct size spend it one a hardened proper one and you'll save from cursing the day away.
                      I also have a set of inverted torx by Lisle, very good never strip and a SNUG fit. The one below it a two piece design that fits a hardened head into the driver. This makes it insanely strong because the head was tempered
                      http://www.ebay.com/itm/LISLE-37710-...5#ht_520wt_907
                      I personally would buy the above T55 and this set to have every single one that would would need.
                      http://www.ebay.com/itm/LISLE-37600-...#ht_2667wt_951
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • alB5
                        • 785
                        thanks everyone, got it off with some more force and realligned everything with no damage done to the shocks or anything else. I'll be sure to get a set of proper torx heads when the time comes, but until then these allen wrenches will have to suffice.
                        No E30 Club
