Engine Painting
  • MaxBell
    • 1391
    Engine Painting
    Hey all;
    How clean do I have to get my engine to paint it? I want to paint the block black just for cleanliness sake, but it's dirty and oily and rusty.
    I've cleaned all the oil off, but there is still some surface rust. I've been cleaning with sandpaper, but it's taking FOREVER.
    Can I just paint it, or should it be bare metal?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • Jafxod
    • May 2011
    • 1301
    Is it in the car?
    • jaywood
      • Jul 2010
      • 4528
      You shouldn't paint over rust....take a wire wheel to it!
      • Dj Buttchug
        • Jun 2010
        • 7683
        might wanna pull the motor out for a decent job?
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Teaguer
          • Sep 2004
          • 6167
          Use roll-on bedliner and fughetaboutit!
          • deutschman
            • May 2008
            • 5958
            depends on how long you want the paint to stay on the motor...
            • MaxBell
              • 1391
              Sorry, should have clarified. The engine is out of the car and mostly torn down. (just a block and head together, front cover is on too)
              • Brezzi
                • Jan 2010
                • 1630
                winnar!
                • lbreevesii
                  • Aug 2009
                  • 412
                  thoroughly degrease, get rid of any rust, then use an engine enamel. I'm a fan of semi-gloss black. It only takes a couple of coats to make an engine look fresh.
                  I don't always wreck cars, but when I do I wreck them into trees.
                  91' 318is S50 swap - The Black Widow
                  • Pac1373
                    • 1746
                    yea, you have to get the rust scale off, wire wheel, chip it with a tool, use a needle gun, whatever but get it off or there isn't a lot of point.
                    Originally Posted by ACMF74
                    i clicked on this cuz i saw p3nis
                    • MaxBell
                      • 1391
                      It's so much woorrrkkk!! WAAAHHHH
                      • CHIF8008
                        • 3447
                        shut up and make the e30 happy
                        -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                        -The Beauty in the Tragedy-
                        MECHANIC SMASH!!- (you all know you do it)
                        Got Drop?? ;-)
                        But of course
                        E30s are know to be notoriously really really really ridiculously good looking
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          If it is just surface rust, Rustoleum will be fine over it. It is made to be put over light rust. If it is flaking off at all, you will want to clean it up first.
                          One of these:
                          http://www.harborfreight.com/power-t...der-95578.html
                          and one of these:
                          http://www.harborfreight.com/4-1-2-h...eel-91279.html
                          Will make the job MUCH easier and provide a nice clean surface.
                          • MaxBell
                            • 1391
                            YUSS I have that wire wheel and I just started using it. Pretty much ate all the rust. It's getting pretty shiny.
