I have 1992 325ic with 60k. Paint is in good condition for paint surface is not smooth. What should I use before wax? I was thinking clay bar.
How to clean up 20 year old paint.
Definitely clay bar. You most likely will pick up a lot of dirt off the surface if you haven't done it on the car before. Make sure you keep the surface and clay clean and lubricated. If your clear coat is oxidized then a polish will be in order.
I used Turtle polishing compound but does not do anything. May be I am doing it wrong. I damp cloth and use it back and forth motion.
Also tried Turtle rubbing compound and that scratch up paint in my e46. Never want to use that.
Paint on my e30 is clean not oxidize.
sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.Comment
i claybard my car and then wash and waxed..but it seems the wax doesnt hold for very long at all..i havent used a polish..would this help the wax stay on and hold its integrity for a while?? i use meguairs gold class paste waxsigpic
93 325i 120k
mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
future mods: chip, m3 cams, headers, turboComment
as it has been said claybar claybar claybarComment
I've used clay bar with ok results. Turtle Wax polishing compound to remove scratches.
But best product to restore paint is Meguiars Ultimate Compound. Check out their videos on youtube. Removes oxidation simply.
I've also heard wet sandpaper. Not sure what grit.Comment
People use this without realizing what it is, what it's used for, and what it does. It's honestly a harsher compound than I think most people should attempt to use and you can easily fuck up your paint in 15 seconds (but not irreversibly). Feel free to PM me if you still haven't fixed the paint on your e46 and I'll walk you through the process.
For your current car, I'd go with a clay bar, be careful and use a lot of lube, then just hand wax it with soft cloths. Locally, kragen (O'reilley's) sells these really, really soft white cloths that are great. However, the edges will mar your paint, so be careful of those. Buy a bunch and only use the centers. These will absolutely not work when cleaning up quick detailer when you're clay barring your car though, since they don't absorb at all. You'll need a drying microfiber for that. If you have minimal swirls and marring over the whole car I'd honestly not really bother it unless you're really determined and willing to do the whole thing well, because otherwise you can waste a lot of effort and it may not look any better (and could easily look worse).The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
what would be a good polish/wax for me to use on my black e30? alot of sun fade really not that bad really i just want to refresh the paint..ive been using the gold class paste wax but it doesnt seem to last long at all..should i use a polish and what would u recomend? ive claybard already so the paint is smooth but the wax just wont holdsigpic
93 325i 120k
Check this guys write up.
Alot of good info. I used his method on 3 different cars and they have turned out beautifully. All in everything cost me about $200 and was well worth it considering I can do about 5 cars before I run out of polish.
I have been very happy with the quality of meguiars products.
Be prepared to set aside 6-8 hours if you are going to do it right.
1.wash
2.clay
3.rougher polish
4.finer polish
5.nxt protector wax/polish.
prep your car properly with painters tape!Comment
Clay will just take a lot of the dirt and impurities out of the top layer of paint.
To make it have that deep, rich luster, it needs to be machine polished. I use Megauires Diamond Cut for cutting compound, Megauires swirl remover for a polish (the most important step on paint correction, most don't realize this) and Megauires #21 Synthetic Sealant for a sealant, then a nice wax of your choice.
For what it's worth, the red car in my signature had an extensive paint correction last spring. I think it took about 15-20 hours to make it look real nice.Last edited by e30austin; 04-07-2013, 11:25 PM.
Can I get an AMEN Brother.....Comment
