Engine bay coated with yellow ???
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    ok i did a search but couldnt come up with anything...
    heres the deal, my engine bay is in good shape but its under some thick grim in one area and a yellowish coat in other places. i heard the yellow coat was applied to prevent rusting when sent overseas??? but it comes off with my fingernail.
    I havnt pressure washed yet cause i want to get most of that yellow coat off, is there a quick way? because honestly i dont want to scratch it with my nail fingernail for weeks...
    Also the grim is in a hard to reach area, but away from vital parts, so should i just soke it with a heavy penitrating degreaser/cleaner then pressure wash it.
    Thanks alot cause i know your guys have alot of great experience with this stuff.
    1987 PRO-3 car /1990 325is (2.7i Concours)
  • skatefreak
    • Jan 2006
    • 116
    I think it's called "cosmoline" and it comes off good with brake cleaner.
    • NC325iC
      • Mar 2004
      • 6565
      yeah so does paint...
      • Jparkr
        HR Admin
        • Jan 2006
        • 3494
        haha yea... i dont think i wanna be that agressive unless i have to, id rather use carb cleaner if thats what if somes down to.
        Anyother suggestions? what has worked for you?
        • Jparkr
          HR Admin
          • Jan 2006
          • 3494
          ok i found alot on search now that i learned it was called cosmoline.
          Thanks for the help though
          • Axxe
            • Aug 2004
            • 3355
            Try Castrol Super Clean
            Keep it slideways!!
            • Dave
              E30 RAT
              • 11675
              My car is the cosmoline poster child - its so ugly I am ashamed . . .
              Ask Will, or Scott, or anyone who saw it 11-5 at alex's place.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • arsevader
                • May 2005
                • 1025
                Since when does brake cleaner remove paint? I think you are thinking of Brake "Fluid".
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  hmmmm break cleaner eh? i was gonna go with gasoline like jordan did but thats worth a try first. thanks
                  • Jparkr
                    HR Admin
                    • Jan 2006
                    • 3494
                    Sorry i forgot, its only on the strut towers and paint... i took care of the intake and valve cov. already. does that change the chemicals?
                    • arsevader
                      • May 2005
                      • 1025
                      Not really.
                      I'd try something like simple green or castrol super clean rather than brake cleaner though. Less toxic and cheaper.
                        • 34844
                        castrol super clean didn't do much of anything to the cosmoline in my car - it also screwed up the color of my intake manifold. I tried EVERYTHING, including the stuff zymol sells specifically for cosmoline removal. The only thing that worked was simple green - I got some 100% strength stuff from costco.
                        Get the engine bay warm, soak it liberally with undiluted simple green, and let it sit for 20-30 minutes. You will see it start to peel off most surfaces, I was able to get huge chunks off with my fingernails. use high pressure water to spray it off, and scrub the areas where it's really thick. it took a few repeats but 90% of it is now gone. of course the paint underneath is now dull from never being polished, but at least it's not so brown anymore.
                        before:
                        after:
                          • 34844
                          had a custom downpipe made, and it turns out that the collectors are the same as small block chevy headers, so they happend to have a set that bolted right up.
                            • 34844
                            Awesome. Did you have them mated to the stock cats and downpipes?
                            there's a 2.5" pipe all the way to the cat. not the best setup but it works for now. I wanted to do dual 2" with new cats but shops around here don't like doing custom exhaust work for some reason, especially on a BMW. :(
                            • Jparkr
                              HR Admin
                              • Jan 2006
                              • 3494
                              Damn it! i tried to get that shit off with gasoline and it got alot of dirt i didnt know about haha, but the cosmoline didnt come off, ok im gonna try the sokin the green method tomorrow...
