Best way to prep rubberized texture for paint?
  • Jand3rson
    • 37587
    We're leaving the rubberized undercoating on my late-model rear valence when we put it on, but I'm still going to be painting it black to match the bumpers and the rest of the car. What's the best way to prep the paint that's over the rubberized stuff to get it ready for primer? I would think sanding, but sanding it is only going to get the raised bumps, and not the whole surface. In order to get the whole surface, I'd have to sand it smooth. Would it be ok to just clean the surface REALLY well, and then shoot the primer?
  • Jand3rson
    • 37587
    Anyone...
    • golde30
      • 11464
      best way? take it off. just get a solvent for rubber and pour it on and scrape off. i always wanted a detexured rear valence.
      IG: @Baye30
      • Jand3rson
        • 37587
        We're not de-texturing it. The rear apron is one of the parts that's going to take the most abuse from road debris, flying up from the rear tires.
        • Digitalwave
          is a poseur
          • 6286
          Just wash it off with a hose so all the big crap is off, and then wipe it down with rubbing alcohol and a towel. I just repainted all my rockers and the lower rear valance and that method worked perfectly.
          RISING EDGE
          • Jand3rson
            • 37587
            Did you prime it first? Should I use primer on mine? We're painting the whole thing.
            • Digitalwave
              is a poseur
              • 6286
              I didn't prime it, I've never had adhesion problems with the undercoated sections of the car.
              RISING EDGE
              • AndrewBird
                The Mad Scientist
                • 11898
                Josh, I would buy some foam sanding pads (the type that are like a sponge with sandpaper on one side. We can use this to pre-sand the surface without worrying about the bumps. We only need to slighty skuff the paint, not take it off to primer.
                While other have had success not using primer and not pre-sanding, I think it would be a good idea and, with the parts off the car, not much more work. It's just good insurance against future wear and tear on the paint.
                • Simon S
                  • Oct 2004
                  • 3758
                  wipe it down with acetone (and let it evaporate off) before spraying
                  -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                  • mentaleeill
                    • 850
                    red scotch brite pad. scuff, thoroughly clean with wax and grease remover, prime and paint.
                    • asubimmer
                      • 6482
                      you could try shooting it w/ a remote sand blaster from a distance, I don't think that would hurt the texture.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        The guy at the paint supply place we went to today recomended hitting the surface with a grey (light grit) scotch-brite pad with hot, soapy water. He also said primer is not needed, however, we will be spraying any and all bare metal edges to prevent any kind of rust.
                        • backtrail69
                          • Jul 2005
                          • 4471
                          I used grey scotch brite on my front valance. We use it alot in the body shop industry as well. As long as there is no chips in it. I would just scuff, seal and paint.
                          :: PNW Crew ::
                          '87 325 4dr, '74 2002
