Sunroof panel misaligned at middle rear
  • johnm01
    • Jul 2013
    • 30
    Photos attached. I have fiddled with the alignment screws on both sides. I can get the sides OK but the sunroof stays too low in the middle. What is going on here and how do I fix it? Looking for ideas here fellas...
    Thanks,
    John
  • HerbE30
    • Nov 2015
    • 538
    Would love to know the reasoning behind this. Mine is the same way. If the sunroof had a truss-like rod, we would be fine. But it doesn't..
    I HATE to say this, but in my car, I'm afraid this is cause from the roof being warped from some sort of collision. Which is why I have held off from paint for the past little while. I don't know I believe, my car only have 1 dent. I've learned with my e30 to assume the worst.
    Someone let us know!
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
    • IRON-E
      • 16548
      Open the sunroof in the forward position and look to the sides (inner area). Theres a small plastic bracket that adjust with 1 hex screw. You will most likely need a second person to adjust correctly, but be careful not to over torque.
      @IRON-E30 aka Edwin:D
      • johnm01
        • Jul 2013
        • 30
        If you can be more specific that would be most helpful, but I thank you very much. I will look for a hex screw on a plastic bracket and see what I can do. I am not getting my hopes up for success. Maybe it will become clear when I examine the mechanism more closely but right now I am baffled at how an adjustment on the sides of the frame can effect the alignment of the panel in the center.
        • HerbE30
          • Nov 2015
          • 538
          Originally posted by johnm01
          If you can be more specific that would be most helpful, but I thank you very much. Maybe it will become clear when I examine the mechanism more closely
          Agreed. I don't recall this in the adjustment DIY.
          Thank you again! I'm not as worried about my car being warped! Such a joyous day!
          20% Accurate
          • cheffy30
            • Sep 2016
            • 1159
            there are a bunch of youtube videos out there.
            the back end should be 1mm above the roof line when closed.
            the hex screw on the inside is where you adjust.
            pull the whole thing off and start fresh.
            clean that all that shit while your in there too... ;D
            '90 325i sedan daily driven
            '85 325e coupe also a daily
            • HerbE30
              • Nov 2015
              • 538
              Yeah Cheffy. I'll be resealing it now. Any suggestions on brands or where to source a good seal?
              I'll also be running new drain lines, but have that covered.
              20% Accurate
              • johnm01
                • Jul 2013
                • 30
                Just to close the loop on this thread...
                I took the whole sunroof mechanism apart. There is no hex screw as IRON-E suggested. I fixed my problem by getting in the car with the sunroof panel removed and pushing down on the roof to bend it at the center by the ~1/4 inch. This was a pretty savage solution but in my case it worked. I am guessing that the previous owner bend the roof up slightly somehow by wedging something into the sunroof cartridge. The car has no accident history and the alignment, body panel gaps, etc do not suggest that a collision could have caused this.
                • IRON-E
                  • 16548
                  I'll get around to my car eventualky and point out the Allen keys I used, and hex screws I tightened on the plastic brackets above the rails.
                  • bradnic
                    • Jul 2012
                    • 3554
                    I believe the six bolts you are referring to are T25 torx, not Allen
                    HOWTOs:
                    DB vert plastic bumpers
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
