rockers
  • oldskool3
    • Mar 2005
    • 401
    rockers
    Rocker panels have some surface rust and I want to get rid of it. Whats the best way to deal with this. I was thinking grinding off all the factory coating with something and than re-spraying with a rock gaurd. Is this the only/ best way to deal with the problem?
    Photoshop by O 16581 72452 5
  • AndrewBird
    The Mad Scientist
    • 11898
    As long as there aren't any holes, that would be the way to do it. For removing paint/ chip-guard, I recommend one of these in a grinder:
    http://www.harborfreight.com/cpi/cta...emnumber=94017
    Works GREAT at stripping paint/rust. Works much better then a twisted-wire wheel, and you don't end up with little piece of wire stuck in your clothes.
    • oldskool3
      • Mar 2005
      • 401
      Awesome thanks for the advice. Do you think its necessary to paint over the rock gaurd or just leave it. I read a thread saying that trim paint is the OE way to redo your rockers if there`s no rust.
      • archemedes
        • 125
        that rocker guard should be painted over as it is just undercoating, and not real strong
        • ddavidv
          • 344
          I don't think rocker guard is black. The stuff I've seen sprayed is usually beige.
          • AndrewBird
            The Mad Scientist
            • 11898
            Depends on the products you get. Most you don't HAVE to paint over, but many I've seen come out a color that is less then nice looking.
            • r75
              • Mar 2008
              • 133
              what is the best paint to recoat the black rocker and valance trim? was it semi-gloss from the factory or more of a satin? Eastwood, SEM?
              • moatilliatta
                • 6142
                do some por15 then paint ;)
                @Zakspeed_US
