Slight Wax Problem
  • Kill The Noise
    • Nov 2008
    • 35
    Slight Wax Problem
    I was waxing my car yesterday in my garage after a nice wash. I was applying the wax, then i had a friend follow behind me and wipe the excess off with a rag. Inevitably during the process some wax got on the black trim pieces, which shouldn't be a big deal, just wipe it off like the rest of the car.
    Unfortunately my friend didn't realize this, and left all the wax along both sides of the car to my dismay. Unfortunately i did not realize this until i pulled the car out in the sun to get a good look.
    Here's what i found
    I immediatley attempted to remove the wax with the towel, a damp towel, and my fingers, but none of it really had an effect.
    Does anyone have any ideas on how to get this stuff off?
    I'd greatly appreciate the help.
  • BingM3
    • 863
    You need a bristle brush to get in the crevices to remove, try a toothbrush in a circular motion with soapy water
      • 34847
      I actually wax my trim peices after I clay them (except the windshield gaskets). Makes it easier and keeps them from oxidizing like most E30s.
      I've had good luck with glass cleaner when I accidentally get some on the window gaskets. You can also try dish soap, that typically will strip the wax off your paint.
      • NC325iC
        • Mar 2004
        • 6565
        same for the first part, ill have to try this second bit
        you dont have trouble till you get it on the convertible boot lid gasket, its got some cloth over the center section... doesnt let go of wax
        • td325ic
          • Feb 2006
          • 788
          I know what you mean on how difficult dried wax and polishing compound can be to remove from black trim.
          The problem is that your trim is likely sun damaged and a bit rough so the wax was able to really stick to it and get trapped in the pores.
          In the past I had to resort to using solvents such as Wax and Grease Remover from an automotive paint store.
          But the first thing I'd try is a Mr. Clean Magic Eraser. That thing works great for so many different applications, I bet it would work well for this too. You can get them at your local grocery store and hardware store in cleaning section.
          Also give isopropyl alcohol a try if you have some on hand.
          • isamemon
            • Jan 2009
            • 257
            thanks for bringing this up
            it is how my trim looks
            let us know what worked
            ok..dumb question....what is ment by "clay them"
            • M-technik-3
              • 18946
              Future reference tape them off with blue painters tape makes waxing jobs easier.
              • daniel
                • 6703
                pics of gf
                http://instagram.com/dslovn.drives
                • pporcaro
                  • Dec 2008
                  • 327
                  clay bar
                  I also wax my trim pieces when i wax the car and dont have that chalky result. Dawn dish detergent is great for stripping things.
                  I wear a suit, I do coke, and I ski...:D
                  That's why I drive a BMW
                  • clavinZERO
                    Hella sick E30
                    • Mar 2004
                    • 2027
                    Griot's Garage: Rubber Prep.
                    "BMW Style 32 Poster-Child"
                    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                    • Japandrew73
                      • 2164
                      Funny this thread popped up because a few minutes ago I just finished waxing and I taped off the trim but when I was waxing i accidently peeled it off.
                      I just bought the Griot's Garage: Rubber Prep. I've had great success with their products in the past and this looks promising!:D
                      • SIR E30
                        • Dec 2008
                        • 110
                        Silicon spray will hide it.. but its not a permanent fix
                        hamilton - E30 Massif
                        • fretburnr
                          • Jan 2005
                          • 1496
                          Peanut butter. Not kidding.
                          Jay
                          • bejbis
                            • Dec 2008
                            • 596
                            +1 at the peanut butter.
                            -Dan
                            • Kill The Noise
                              • Nov 2008
                              • 35
                              Awesome, thanks for all the suggestions, guys. When the e30 gets back from the shop i'll be sure to let you know how it turned out.
