IS Side skirt jig/template
This is a sticky topic.
  • bmwstephen
    • 2463
    as I just said, after drilling the holes, you should coat the grommet that is to be inserted into them with some sort of sealant, blocker, or primer.
    • bernzpeed
      • 3917
      Originally posted by bmwstephen
      Bernz,
      Alternatively what you can do is secure the clips that are to clip against the rocker onto the skirts. Dab the POINTED TIPS of the clips with some paint and try to pre-fit/mount them on the rockers. It should leave a mark on which spots to drill. Thats how Ryan G did my skirts.
      Be careful when drilling, behind the rockers are some electrical wiring that you don't want your drill bit to go through
      And wen u eff up. Fill with jb weld and redrill. Make sure that before you install plastic grommets that go into those holes (which in turn the clips' heads snap into), you coat the neck with some sort of sealant to prevent rust around the cavity area it's going to be inserted into
      Wow, that's a great idea. I'm surprised I didn't think of that. lol. That's what I would do with sheet rock and door locks.
      I already was thinking of sealing it with a bead of silicone sealant so water can't get through. Although, after drilling I could spray it with a little primer as well to protect the metal parts.
      Thanks a bunch for the tip. I'm gonna try to work on it tonight. Will post photos.
      Have a great weekend guys and dolls!
      89 E30 S52
      Transaction Feedback.
      • acolella76
        • 2950
        I did pretty much what stephen said. Only drilled one hole and held up the rest of the skirt with the clips and double sided tape. Hasn't even budged.
        -Alex
        • lbreevesii
          • Aug 2009
          • 412
          subscribed. I would like a template or visual guide for this as well. I'm not entirely sure I know where all the hardware goes.
          I don't always wreck cars, but when I do I wreck them into trees.
          91' 318is S50 swap - The Black Widow
          • RAYREY
            • 212
            Looking for ix jigs check this out Maximillian http://www.bmwmobiletradition-online...53&hg=51&fg=20
            1991 325i coupe
            1992 318i conv
            2002 540i sedan
            What did the e30 owner say to the other e30 owner? LOOKING GOOD!
            • bernzpeed
              • 3917
              I did it.
              Parts you need:
              51 71 1 947 059 Cover left (fender)
              51 71 1 947 060 Cover right
              51 71 1 947 063 Cover left (body)
              51 71 1 947 064 Cover right
              51 71 1 933 719 Clamping bolt
              NOTE: You have to remove the bolt at the bottom of the fender and replace it with a similar but longer screw bolt instead of using this.
              Trust me it will work better.
              51 71 1 927 439 Plug (You need 2)
              51 71 1 938 940 Clamping (You need 10)
              51 71 1 932 996 Grommets (you need 12)
              51 11 1 942 789 Rivet (you need 4)
              51 71 1 959 929 Clamps (You need 12)
              The whole thing will cost you about $200 including gas money to go to the dealership and lunch.
              Thank you to www.bmwconcordparts.com for all the parts.
              <b>My car before the install
              Brand spanking new, straight from the dealership
              Figuring out where to fit all the clips
              Test fitting the whole thing.
              NOTE: Make sure you the both pieces TOGETHER.
              Otherwise, you will get this gap
              Marking the tip of the clips so it transfers to the body.
              Drilled out a hole with a 3/8 step drill
              Inserted the grommet
              Tap tap tap
              Tadah!
              Installed the bottom clips
              Lined up right
              Making a hole for the rivet
              Lined up perfectly the second time around
              My riveter is too small for the BMW rivet
              Temporary fix
              </b>
              When it stops raining, I will take a nice photo of the car.
              89 E30 S52
              • lbreevesii
                • Aug 2009
                • 412
                Double post of awesome. Ty Sir. can we please get a sticky on this thread or get it posted to the DIY Section.
                  • 37828
                  Very nice work, I can't wait to install mine!
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    agree I vote sticky
                    • TrentW
                      • 2815
                      FINALLY! Thanks alot for the writeup bernzspeed--gonna finally get around to installing mine next week. Pics to follow.
                      • bernzpeed
                        • 3917
                        I'm glad to have helped.
                        89 E30 S52
                        • Garageaholic
                          Freestyle Fabricator
                          • Dec 2005
                          • 5204
                          What are the dimensions of those holes? Wasn't there mention of a template?
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          Instagram.com/garageaholic
                          Youtube.com/garageaholic
                          • bernzpeed
                            • 3917
                            3/8
                            I used the actual side skirt as the template. I used the marker to dot where I should drill a hole.
                            89 E30 S52
                            • motors4me
                              • 120
                              What were you intending to type here?
                              • motors4me
                                • 120
                                NOTE: Make sure you tape both pieces TOGETHER.
                                NVM, I found this in your how-to thread!
