does anyone know where i can get one? I have a brand new set of IS Side skirts but do not have the jig or template to drill holes in. If someone can direct me to the right person, I would really really appreciate it.
IS Side skirt jig/template
This is a sticky topic.
89 E30 S52
Transaction Feedback.Tags: None
- Stuck
My car luckily came with IS skirts and have the holes pre-drilled. I'm selling the skirts, so maybe I'll make an outline of them for r3v asshat's to use soon
<3
If drilling ain't your thing, you can use the factory clips at the bottom, which hold pretty well, and thin double sided tape for the top.
Originally posted by ak- View PostMy car luckily came with IS skirts and have the holes pre-drilled. I'm selling the skirts, so maybe I'll make an outline of them for r3v asshat's to use soon
<3
If drilling ain't your thing, you can use the factory clips at the bottom, which hold pretty well, and thin double sided tape for the top.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
I have some too and haven't installed yet. I was going to quintuple check my dimensions before drilling anything.
Of course, a template would greatly assist me in my efforts. Thanks!!!Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic
Yes!!!!!!!!!!!!! Thanks!Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Originally posted by ak- View PostThe pressure. I can feel it.
I'll see what I can do when I have access to my car.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Bernz,
Alternatively what you can do is secure the clips that are to clip against the rocker onto the skirts. Dab the POINTED TIPS of the clips with some paint and try to pre-fit/mount them on the rockers. It should leave a mark on which spots to drill. Thats how Ryan G did my skirts.
Be careful when drilling, behind the rockers are some electrical wiring that you don't want your drill bit to go through
-Blame my typos on my fat fingers & Droid Charge
And wen u eff up. Fill with jb weld and redrill. Make sure that before you install plastic grommets that go into those holes (which in turn the clips' heads snap into), you coat the neck with some sort of sealant to prevent rust around the cavity area it's going to be inserted into
-Blame my typos on my fat fingers & Droid ChargeLast edited by bmwstephen; 09-28-2011, 10:23 PM.
