CF/FRP Hood Fitment
  • Skafrog
    • 1732
    CF/FRP Hood Fitment
    Guys, what is the latest on the fitment/weight of the VIS / Carbon Creations / Ireland / DTM Fiber Werks / etc hoods??
    The hood is for a GTS2 car, so it needs to be light, but can't bow up in the middle at speeds. Anyone have track experience with a LTW hood?
    Thanks,
    Rob
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
  • Kershaw
    • 11822
    get the VAC motorsports one.
    AWD > RWD
    • SGT4677
      • 253
      My hood works just fine on track,no lifting,shaking or any other weirdness.It fits ok,but pinches at the rear corners a little,compared to a stock hood and saves about 20 lbs.All the stock hinges and bolts work fine.Its a VIS IIRC.
      1990 325is "the rat"/ E30 Warsteiner tribute racecar/1985 325e "faded Glory"/ 1968 Chevy II Nova "the baby"/ 2001 525i 5spd purchased May 2013 with 16k miles. Plus other junk that annoys the neighbors.
      • 2002maniac
        • 4260
        I had a IE pin on hood skin that was under 15lbs. It did lift in the middle on the straights so I added some reinforcement across the front (wish I had a pic, sorry). You could also add a 3rd pin up front to solve the problem.
          • 34847
          if you don't care about looks, they fit the car basically.
          the VIS ones are heavy - it's just a FG hood with a CF overlay. And like 10lbs of gel coat...
          if you want quality, it's going to cost. I don't think MA Shaw makes a full CF E30 hood anymore, but competition concepts does I think.
          My MA Shaw is 10lbs. I think they have a FG/Composite one that weighs about the same. If you're painting it anyway, it probably doesn't matter much what the material is. Mine fits perfectly.
          • Jalves619
            • 596
            The MA Shaw site still lists one, but with a urethane core for 750.
              • 34847
              Yeah, they used to offer one that was 100% CF for around $900.
              • Kershaw
                • 11822
                $950. 12lbs. "Special urethane core construction for light, yet extremely rigid composition"
                lol.
                the competition concepts piece looks very high quality. $999. 10lbs.
                AWD > RWD
                • Bearmw
                  • 1323
                  I got a deal on a used but never mounted DTMfiberwerkz CFRP hood. The company says it weighs 16 lbs. which feels about right but I never weighed it. It fits fairly well but appears a little narrower than stock but I haven't measured the difference. Finish is fine but I will definitely end up painting it body color some day.
