Ignition lock
So the ignition lock is a special case - no rebuild kit for it that I've found. Removal and install are really easy - DIY here. You have 2 options around rebuilding a worn ignition lock cylinder:
1) order a coded lock cylinder brand new from the dealer that matches your current car. part number for this is 32-32-1-153-046
2) buy a new ignition lock plus key that does not match your doors, trunk, glovebox etc, part number 32-32-1-152-474. Live with the extra key or rebuild your current door locks to match the new key.
![](https://farm5.staticflickr.com/4339/36239648881_fba1ebc43b_b.jpg)
Obviously if you do the latter you can't order dealer coded keys anymore :-)
Both part numbers above appear to be good for all E30, E28 and E24. Here's the realoem page for the air bag car ignition lock (part 4 in the diagram - the 307,308,and 309 part numbers appear to be NLA).
![](https://farm5.staticflickr.com/4376/35979402220_4d493ec2e9_b.jpg)
UPDATE: FCP Euro blog has an 80s mercedes ignition lock replacement post. Procedure should be pretty much identical.
