Door Stuck Shut
  • tcp88
    • May 2016
    • 106
    Door Stuck Shut
    So this seems like a good place for this.
    I will update this as soon as I get all the information as to what happened.
    My friend borrowed my 89ix and when I got it back the drivers side door was stuck shut.
    What, if anything, can I do to get it open to start fixing whatever it is that broke (the locking mechanism I am assuming) - it is stuck shut and the door card is off.
  • ELVA164
    • 4861
    Is it possible he double-locked it?
    • jeffnhiscars
      • Jun 2011
      • 6011
      Wouldnt he be able to open it from the inside if it was ?
      Alice the Time Capsule
      • tcp88
        • May 2016
        • 106
        So supposedly all he did was locktite in the three bolts surrounding the locking mechanism
        • jeffnhiscars
          • Jun 2011
          • 6011
          If the door panel is off did you try to pull the rod that connects the handle to the lock
          • ELVA164
            • 4861
            No, that's the point of double locking.
            • ELVA164
              • 4861
              Sounds to me like he used too much Loctite and it bled into the mechanism, seizing it up.
              • jeffnhiscars
                • Jun 2011
                • 6011
                So if your car catches fire you dont want whoever is in there to get out.
                at least there's a point to it :-)
                • parkerbink
                  • Jun 2004
                  • 10138
                  Ummm why did he Loctite your lock mech?
                  • Maddog
                    • Dec 2006
                    • 117
                    If in the double lock position and the key will not turn lock, most likely you need to rebuild the cylinder or buy a new one coded for your car. To unlock, push down on the pull knob and lift up the door handle from the outside.
                    • parkerbink
                      • Jun 2004
                      • 10138
                      This might come in handy:
                      FS: Lock Set - Trunk, Doors, Ignition - $85
                      • tcp88
                        • May 2016
                        • 106
                        I could be wrong but it seems as though the locking mechanism is non-functional as I get no response from working the lock rod or the door-handle.
                        • youngmineeh
                          • Oct 2016
                          • 88
                          In my case, the locking actuator was seized, on both the passenger and the driver door at the same time... This prevented me from unlocking the car from the lock cylinder, locking knob, and even from the trunk.
                          I somehow got the driver's door to open with it being locked. I then removed the door card and removed the 2 screws that held the locking actuator in place. This allowed me to manually lock/unlock my doors until my replacement actuators came.
                          • ELVA164
                            • 4861
                            The two non-immolation reasons for it are to make it so only your key will open the car (only master keys can double lock) or if you discover someone trying to steal your car you can lock them inside until the authorities arrive. Option 2 probably doesn't end well for the car, but I guess that's what insurance is for? At any rate, it's designed to only unlock the car if a master key is used in the driver door cylinder.
                            • AngeloF10
                              • Dec 2015
                              • 191
                              Originally posted by youngmineeh
                              In my case, the locking actuator was seized. On both the passenger and the driver door, at the same time... This prevented me of unlocking the car from the lock cylinder, locking knob, and even from the trunk.
                              +1 I experienced exactly this on my passenger side
