Cabrio drive door window hits weather stipping
  • Rosica
    • Jan 2004
    • 240
    When I close the driver door on my cabrio the window doesnt seat right in the weather stripping, it gets stuck out 1/4" at the top. Can anyone help.
    07 335xi Sport
    00 S2k
    01 A4 1.8t-Sold
    88 M3-Sold
    91 325iC-Totaled
    89 325iS - Sold
    87 325-Totaled
  • parkerbink
    • Jun 2004
    • 10138
    This has happened to mine sporadically since it was new. I just put the window down & back up after closing the door to reseat. Sometimes months go by without it happening again, in fact now that I think of it it hasn't happened since May when an asshole put a rock through it and I replaced the window.
    • Rosica
      • Jan 2004
      • 240
      Mine jsut started happing one day to. it is really pissing me off.
      07 335xi Sport
      00 S2k
      01 A4 1.8t-Sold
      88 M3-Sold
      91 325iC-Totaled
      89 325iS - Sold
      87 325-Totaled
      • BS87
        • 1606
        Mine does that. If i close the door with the window up, i have to push in on it to get it ot seal. If i put the window up with the door closed, it seats fine.
        I think it has to do with the little adjustment screw, and the window traveling too far up.
        • M-technik-3
          • 18946
          Mine too, but haven't started any real work on that car yet.
          • ///M42 sport
            • 3952
            same here
            • mgold
              • 709
              I'm in the same boat. The stealer wanted some ungodly amount to alighn the windows and top. Some day I'll pull off all the interior panels and figure it out.
              • BS87
                • 1606
                The bently outlines it pretty well, and while i replaced my drivers side door lock, i figured i'd try it. I got it to eathier sit up WAY to high, or sit down about an inch below the top, never could get it lower. Took a while to get it where it was now.
                The fact i had a few beers in me probably did not help the "fine adjustment" part though.
                • Mike 91 318ic
                  • Jun 2004
                  • 429
                  there is a adjustment screw on the doors just about the map pockets that will move the window up or down... It's an easy fix that takes 5 minutes. Just remove the round plastic cover to access the adjuster.
                  M
                  you can see the round cover on the passenger door in this pic just above the map pocket.
                  • ///M42 sport
                    • 3952
                    I wondered what that was for. thanks. Anyone have an extra cover piece?
                    • BS87
                      • 1606
                      Hm, thanks mike. The bently had me tearing apart the door to get to what is probably the same screw/nut
                      • arnib
                        • 52
                        Okay that's incredible.
                        I've had this problem for a while and I never got around to taking the door apart to look at it.
                        You know what,
                        i'm going out right now to have a look through that hole :)
                        • NC325iC
                          • Mar 2004
                          • 6565
                          are you sayin i took off my delicate waterproofing (shower curtain with glue)behind the door panel for nothing
                          • BS87
                            • 1606
                            What i want to know is how the HELL little pebbles and such get in the bottom of the doors that are sealed up from the factory.
                            • ///M42 sport
                              • 3952
                              I checked the hole by the map pocket but there it was covered with insulation.
