Friggen broken seat
  • rammstein
    • Jul 2009
    • 367
    Friggen broken seat
    What a lovely project replacing my seat shocks has turned out to be. Turns out you need to be a gorilla to compress the shocks, so I had to go to home depot to buy a C-Clamp. When I got there, I found a really cool clamp gun thingy and bought it instead. It worked fine on the vertical adjusters, but the thing is so bulky that it doesn't work for the backrest, so I had to stop there tonight and I'll have to go to home depot AGAIN tomorrow to buy something that will work. I guess my choice of clamp wasn't as slick as I had anticipated.
    So then I figured "hey, lets see how nice the bottom adjuster is!" I put the seat on the ground, sat on it, and the vertical adjusters do nothing. Nothing. I have no idea why not, everything seems to be connected.
    Then, the icing on the cake, the left bolster attachment point is broken off of the seat frame. There is a spot where it is supposed to be welded to the frame of the seat, but the weld apparently gave up.
    So now what? Can I take it somewhere to get it welded back on? Who does that, a muffler shop?
    If I had known what I was going to encounter on this voyage, I would have just bought some new sparco seats or something. Now I am $180 deep into a seat with a broken a weld and a seemingly busted vertical adjuster, and the loose bar thingy I mentioned on another thread. Am I just having bad luck? I just bought this car, and it already consumed the A/C compressor and needed an oxygen sensor that I didn't anticipate. I thought it was going to be close to perfect. Ok, no more venting.
    Can anybody help me out here with some advice or at least a soothing voice?
    E30 M52B28
  • BrewCity11
    • Mar 2008
    • 2335
    The set of sport seats i'm freshening up now has the same weld problem. Not completely cracked yet, but will be getting it fixed anyways.
    Grind all rust off, take somewhere to have welded, then coat in rustoleum black. (or por 15)
    turk@gutenparts.com
    • rammstein
      • Jul 2009
      • 367
      GOD DAMMIT!!!!!!!! How the hell does a person install these backrest shocks. I've tried for TWO nights. I've bought 2 different clamps trying to compress these bastards into place. Has anybody on here ever successfully done this? How did you do it? How? I don't get it. I used to think I was smart.... starting to feel pretty dumb.
      E30 M52B28
      • td325ic
        • Feb 2006
        • 772
        Yes, I've replaced the shocks a number of times. It's easy with the right tools.
        You have the right idea using a clamp to compress the shock in order to slide them onto the pins on the mechanism.
        Have you removed the mechanisms from the seat? It's easiest to remove the mechanisms from the seat first.
        Buy this clamp from Home Depot:
        (The shock in the photo is like new and is easily compressed with the clamp.
        Take out the pin on the bottom of the clamp so it opens wider
        Here's some instructions on how to take apart the sport seat:
        Good luck, PM me if you have any specific questions
        • slo325i
          • 417
          Damn... i think a s52 swap is easier than a seat fix, no???
          '89 325i - Totaled... good bye my love...
          '87 327i budget stroker - SOLD!!!
          '92 240sx - ca18det powered drift toy - SOLD!!!
          '89 325i - coupe - NEW daily
          '96 Audi A6 Quattro- Grocery getter/baby hauler
          '99 Busa - weekend wheelie monster
          • rammstein
            • Jul 2009
            • 367
            Dude- thank you SO much. Actually, I bought that VERY tool last night. It worked like a charm on the verical adjusters. I was trying to replace the backrest adjusters without taking the back of the seat off. For 2 days. Then it dawned on my to take the back off. It only took about 30 seconds after that. So now that I've got that down, I need to figure out:
            A) Why the vertical adjustment doesn't seem to be working even with the new shocks
            B) Why the seat bottom rail thingy is loose (which makes the whole seat rock while driving, VERY annoying
            C) Get the broken bolster frame connector welded somewhere.
            E30 M52B28
            • ldsbeaker
              • Aug 2004
              • 3098
              Thanks for the link!
              Slicktop City!
              • rammstein
                • Jul 2009
                • 367
                Well so OK- I got all 4 shocks replaced. The backrest seems like it is going to work fine. However, the vertical adjustment doesn't really do anything. When I push down on the back lever, isn't the back of the seat bottom supposed to pop up? And when I push down on the front lever, what is supposed to happen? Nothing is happening with these. It appears like the vertical adjuster is at least connected to both sides- the mechanisms on both sides move when I push down, but no action. Any thoughts?
                E30 M52B28
                • kenika65
                  • Aug 2007
                  • 1336
                  Damn good post What are the shock part# and where are you all buying them from?
                  1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                  1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                  • Rhys
                    • Jul 2008
                    • 103
                    Thank you for the useful info on the sport seats!, I really needed it.
