Dash crack prevention?
  • kencopperwheat
    King of Kegstands
    • 14396
    I just found a 1cm long crack under the lip of the passenger side depression. Is there anything to do to prevent it from spreading? It's not visible from inside the car, and I'd like it to remain that way. I was thinking about wiping some epoxy on/in it.
    Originally posted by Gruelius
  • reelizmpro
    • 9558
    Just like windshield cracks, it helps to fill it with some type of adhesive to keep the crack from spreading.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • AndrewBird
      The Mad Scientist
      • 11898
      Drill a small hole at each end of the crack. This will keep it from spreading farther. That's about all you can do.
      • Van Westervelt
        • 9365
        drill and fill. they pray. lol
        • Cobra Jet
          • Apr 2008
          • 278
          what does drilling a hole actually do - never heard of that method...
          Exactly why does the dash eventually crack?
          • Vethen
            • Aug 2009
            • 186
            Sitting out in the sun the dash gets dry, and without being moist the little stresses it takes makes it crack. Thats why people wipe there dashes with special wipes :)
            And drilling a hole at the end of a crack evenly distributes the crack in a circle, and is harder to break through.
            Look at it this way. Your opening a really large packet of ketchup and are tearing it, then make a hole punch in it. It's easyer to rip the started tear then pulling past the hole.
            Hope it helps
            ///B///M///W///
            • Cobra Jet
              • Apr 2008
              • 278
              interesting info about the holes -thx!
              • thedeal
                • 643
                We do this all the time with cracks on reciprocating airplane engine, cooling fins, It relieves the stress of the crack by removing any sharp edges for the crack to continue on. Should work. Drill n' Fill!
                • guibo09
                  • Dec 2008
                  • 834
                  stress is inversely proportional to the radius of the hole. ie, the smaller the hole, the larger the stress. a crack tip is like an infinitely small hole, so you get an infinitely large stress. this makes the crack propagate real quick.
                  the technical term for the repair is a stop drill.
                  90 E30 325i
                  • noE30
                    • Jun 2008
                    • 2260
                    what do you guys use to fill the cracks?
                    Flickr
                    @michael.colby on Instagram
                    "All he needed was a wheel in his hand and four on the road"
                    • e34john
                      • Apr 2006
                      • 3599
                      Anyone try something like the leatherique leather crack filler on their dashes?
                      • dude8383
                        • Jan 2005
                        • 10387
                        x2
                        i was thinking about doing this but my little can has dried up completely.
                        what are you guys using to "fill" the crack? what are you using to match the color the of the dash after?
                        • jamiholzbach
                          • 311
                          drilling a hole!
                          The first time I actually saw this was on a couple of vintage WWII bombers on the acrylic side windows, and yes it works!
                          • noE30
                            • Jun 2008
                            • 2260
                            bump, for info on filling the crack
                            Flickr
                            • noE30
                              • Jun 2008
                              • 2260
                              Bump again, looking to do this soon. I tried searching and couldn't find any other threads about filling the cracks. Anyone know?
                              Flickr
