Bringing the black back to an M-Tech II wheel part
  • Jand3rson
    • 37587
    As I have noticed on nearly every single M-Tech II wheel I've ever seen, the center horn section is always a pretty decent amount lighter in color, almost a different color, than the rest of the wheel, which is obviously attributed to the wheel being leather and the center section being vinyl.
    I'm planning on dying the center section a deep black, to match the rest of the wheel. Is there a certain product any of you guys would reccomend? I was planning to just use an automotive vinyl dye.
  • bmwm3n528
    • 3654
    May try cleaning it with some very diluted purple power. If that doesn't work...like you said, I guess dye it.
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    • Jand3rson
      • 37587
      What is purple powder? I was alos thinking of cleaning it with some VERY diluted Castrol Super Clean.
      • RCWells
        • 3589
        Ya, clean it first. Then I would try Forever Black, or Mother's Back-to-Black. Both of those are good treatments for restoring black trim/vinyl etc., not dyes. If they don't work to your satisfaction, then maybe try dyeing it. I use the latter on mine, and it does a good job.of making it dark again. Of course repeat applications are necessary on occasion.
        [THE 501 club - Founding Member]
        • bmwm3n528
          • 3654
          Purple Power / Simple Green...same thing. Just a really strong cleaner/degreaser. You can get it like anywhere, Wal-Mart/K-Mart, etc, etc.
          Can be the jack of all trades, can also be your worst enemy if not used carefully. Should be harrmless on black vinyl though, just be careful with it.
          Trevor Ely
          • bimmerphile
            • 3495
            the lighter color is UV degradation, not dirt.
            Dye it with Vinyl dye.
            • Jordan
              • 12916
              Yup. I used dye on mine, very happy with it.
              https://mtechniqueabs.com/
              • Digitalwave
                is a poseur
                • 6300
                Better off dying anyways. If you clean and then put a greasy product on it it will constantly wear off and have to be reapplied anyways, and not feel very good on your hands.
                RISING EDGE
                  • 34847
                  back to black is the most worthless product ever.. clean it up and dye it.
                  • Jand3rson
                    • 37587
                    Thanks for all the help, guys.
                    • DSchultz325e
                      • Aug 2004
                      • 1158
                      I retired my E30 for now...
                      E46 323i
                      David Schultz
                      • Sean
                        • 5793
                        Josh, let us know how it turns out! :D
                        - Sean Hayes
                        • bimmerphile
                          • 3495
                          what are you talking about? I always lube up my hands before some spirited driving.
                          • Jand3rson
                            • 37587
                            Yes, you get better lubrication on your "shift lever".
                            • RCWells
                              • 3589
                              And you get much better steering feel with your hands placed on the center hub rather than the outer part of the wheel :roll:
