An M3 with a 5000rpm redline?
  • James Crivellone
    Head Janitor
    • 6305
    Finally got around to modding my m3 cluster
    at least my tach is correct now :)
  • BENdashdash
    Tom is not my friend
    • Aug 2004
    • 2506
    Nice, but you look a little low on gas :P
    BTW, is your odometer accurate yet?
    • James Crivellone
      Head Janitor
      • 6305
      Yes, that is actual mileage
      • DanGillan
        • Mar 2004
        • 4061
        how did you change it? or did you just use your old speedo with m3 needle?
        Dan
        • James Crivellone
          Head Janitor
          • 6305
          Temp, Fuel, MPH/Odo and Oil Temp are Unmodified (minus odo rollup) M3 Gauges.
          The Tach is an M3 Gauge, with a eta faceplate and an eta coding plug
          • bwanac
            • 3354
            Pics no working. :|
            EDIT: Working now. Server down possibly for a bit.
            • T.Dot E30
              • Mar 2004
              • 536
              pics work for me
              • bwanac
                • 3354
                Thats awesome. I want to do dat.
                • Stu Mc
                  • 4083
                  One of the things I like about the M3 instrument cluster is the 8k tach card with redline starting at 7200. Your cluster still looks great though.
                  Did you roll your odometer? I didn't know that could be done so that the odo still works. I need to roll mine forward about 120,000 miles (swapped clusters). Can I do it?
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Yeah I rolled it, was a bitch and a half, had to completely take it apart, and pull the pins and reset the damn thing, finally did it though
                    • UNHCLL
                      • 8790
                      Riceroni, the New SanFran. treat.
                      Yes, I'm sure you'll tell me you will put the M3 tach in when the motor is done... but thats dumb, just wait to put the whole cluster in then sorry... rice-a-rific
                      Below the radar...
                      • James Crivellone
                        Head Janitor
                        • 6305
                        It looks fine...
                        and I wanted the oil temp monitor
                        and don't even pull the rice bullshit with me
                        • Rob
                          • 8166
                          whats wrong with a real oil temp gauge?
                          BEERTECH
                          • James Crivellone
                            Head Janitor
                            • 6305
                            I perfer using OEM parts over aftermarket, if no oem option is around then I go aftermarket.
                            Personal Preference
                            • Digitalwave
                              is a poseur
                              • 6299
                              Looks nice, is the tach 100% accurate now?
                              RISING EDGE
