Where's Your Door Chime?
  • Aptyp
    • 6584
    What did all of you do with it. I ripped mine out and threw it away. Wanted to know if others find it irritating and if they've disconnected it.
    73
    Didn't know e30 had one.
    17.81%
    13
    Took it out/Disconnected
    54.79%
    40
    Still have it.
    27.40%
    20
  • xwill112x
    • Jan 2009
    • 4236
    i still have mine.
    • Atreus
      • 1846
      took it out years ago. one time, it got stuck in the "chime" position i guess, really annoying drive home that day....
      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
      1991 325iC - Calypsorot Metallic
      1994 540i - Granitsilber
      Originally posted by scabzzzz
      I've had blunts cock in my mouth, but I'm not gay.
      • xwill112x
        • Jan 2009
        • 4236
        Originally posted by Atreus
        i took a mg42 and opened fire on it years ago. one time, it got stuck in the "chime" position i guess, really annoying drive home that day....
        fixed for actual results of a hour drive with the door chime
        • Stephen
          Шлем ишака
          • 10774
          garage
          • Desaevious
            • Aug 2007
            • 3810
            Disconnected. It got stuck on once, it pissed me off something royal.
            SC*AR (Schwarz Army)
            • Bimmerista
              • Nov 2005
              • 5425
              I have 2 sitting in my garage. Its the first thing I do when I buy a new e30.
              • Aptyp
                • 6584
                same
                • Gooch
                  • Dec 2006
                  • 1674
                  In the trash where it belongs, that thing is fucking annoying.
                  '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                  '87 535i - Vacuum brake conversion [SOLD]
                  '93 525iT - 5-speed swap - 320k and counting
                  '09 328xi - 6-speed
                  • robrez
                    • Jul 2008
                    • 3376
                    Tossed mine. Although I wish my car had a chime for when I leave the lights on
                    January 2012 COTM
                    • IRON-E
                      • 16548
                      +1
                      @IRON-E30 aka Edwin:D
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        +2!!!
                        The worst part about the lights on an e30 is that the headlights go out with the key and it's easy to forget they are on if you had them on during the early evening. Caused a dead battery once :(
                        JMy chime is hanging right were it's supposed to be, just not plugged in hehe.
                        john@m20guru.com
                        Links:
                        • NeoMishMoo
                          • Jul 2009
                          • 448
                          I didn't know they had one until I started taking stuff apart and found it halfway plugged in, I just took it out and now it sits in a box somewhere. I've never even heard the sound, maybe I'll go hook it up and see if it
                          works. Oh wait I cut off the connector :(.
                          For any of you that never plan on hooking it back up you can cut the connector off and use for the analog clock install, it fits without having to cut off the tabs like with the power window connectors.
                          Then again my clock doesnt work, but I don't see how the connector would matter.
                          West German BMWs, they just don't make the same as they did before the wall fell.
                          ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
                          • BlueBMW
                            • Jan 2010
                            • 219
                            +3!!! I killed my battery twice by leaving the lights on. I guess I'm spoiled by newer cars. My E34 tells me in words... "Hey idiot, your lights are still on!!" Although my old 85 mercedes at least buzzed at me.
                            Maybe i'll look into a way to rig this up with a little relay off a wire from the light switch and ignition switch then wired to the gong? It would have to supply power to the gong when the ignition is off and the lights are on... so hmm... probably not too hard to make work.
                            '88 325ic - Vert in winter baby!
                            '91 318is - Gone :(
                            '95 530i - Gone :(
                            • kronus
                              • Apr 2008
                              • 13020
                              I threw mine into the woods on the side of the highway. Might still be there.
                              cars beep boop
