Re-Carpeting the Rear Deck [PICS]
  • bmwman91
    • Oct 2004
    • 3133
    Twenty years of baking in the sun & heat left me with an ugly rear deck. It was 3 shades of gray, and had non-functional speakers in it from sometime around 2001. I have overhauled my audio system extensively, and I do not use rear speakers. The only reason they were in there was to fill the holes.
    Well, I finally decided to tackle the task of covering the rear deck with some nice new black cabinet carpeting so that it would match the other new upholstery I put in last year.
    I used some black speaker carpet from Parts Express (no latex backing, that makes it too rigid to drape nicely). It was $5 for the 36"x54" piece I got. Anyway, pictures are more useful.
    I started by skinning the deck. As with all cosmetic projects, it begins with you feeling a knot in your stomach..."man, I had better not mess this up." It won't come off cleanly, so be very careful to make sure that it isn't taking half the cardboard with it.
    After getting all of the carpeting off, I rubbed it down with some isopropyl alcohol to get some gunk off, and then used some 2" painters tape to rip off the loose paper bits. I finished up with a shop-vac & a brush attachment.
    OK, I know this looks hokey. Yes, those are popsicle sticks, hot-glued & pop-riveted onto the thin cardboard sections. Those sections were totally warped from years of sun & heat, and the tabs never went into the slots in the rear bulkhead, and the plastic vents were always falling out. It turned out that popsicle sticks were the most suitable bits I found on-hand. Hokey, sure. But it works, and nobody will ever see it.
    Next I needed to fill the speaker holes. I found some 18ga aluminum sheet, cut it to size, applied some spray adhesive & riveted it on.
    The rear of the deck is covered with Damplifier & some 1/8" closed cell foam. I added Damplifier to the aluminum sheets to prevent unwanted noises.
    If you are ever in a position where you need to glue fabric, vinyl or other stuff that you do NOT want to have to worry about it falling off...this is the stuff for you. I have tried a variety of off-the-shelf 3M products over the years, and they all failed horribly.
    The best results come when you apply this to both surfaces being joined, and let it sit for at least 30 seconds after spraying it before you mate the parts.
    The point of no return...plan it all out in your head BEFORE you even take the cap off of the spray adhesive. This carpet draped very nicely. The only spots (2 of them) where it bunched up unavoidably are also spots that are 100% hidden behind the rear seat back. Once I trimmed everything else (at the end), I carefully cut off the bunched parts & aligned the edges. It is undetectable from 3ft away.
    I applied the glue in 5 stages.
    1) The big, lower flat area only, none of the vertical parts surrounding it.
    2) Everything in front, left & right of the lower flat area, but none of the rear upper flat part.
    3) Rear upper flat part & the vertical part coming from the lower spot.
    4) The rear vent area & the brake light housing.
    5) Flipped it over & got more of the brake light housing & any other spots that I missed along the edges.
    After letting the glue dry for 20 minutes (the carpet is very breathable, this helps the glue to cure faster), trimming began.
    An upholstery blade in an X-acto knife is suitable. Always cut when pulling INWARD. You want any forces that you put on the material you are cutting to pull it onto its substrate, not off of it!
    I was mostly done...just needed to cut out the vents.
    Yes, it looks a hell of a lot better than the old junk. Apparently I got some water spots on the camera lens...need to do something about that!
    The vents sit in there much more nicely than they did before. I didn't trim the carpet out, only made slits, so the vents sit more tightly in there now.
    So there it is. I didn't take any pictures of it in the car. It was dark out, and raining so any shots in the car would have been blown-out with the flash. You can see how much cleaner it looks now anyway!
    Transaction Feedback: LINK
  • Bimmerista
    • Nov 2005
    • 5425
    Nice kitchen
    • Jean
      • 18228
      Good job! Best diy for the rear speaker shelf i've seen yet. I have an e30m3 rear cover on mine w/o the 3rd brake light and it's faded/blue color, I'll have to do what you did with yours.
      • StereoInstaller1
        GAS
        • 22679
        If you find yourself doing much more of this particular kind of work, especially with Vinyl, quit with the cheeseball glue.
        Yeah, I know, I have used likely 200+ cases of that exact stuff. Been using it since I did my first "carpet covered door warts" back in 1981. Trust me on this, that stuff sucks.
        Get yourself a $10 spray gun, just your normal cheap-o harbor freight gun. Then, get a gallon of DAP/Weldwood brand "Landau Top Adhesive". Simply pour from the gallon and spray, about 90PSI works well. You let your rattle can crap set up, right? This stuff sets up about 1000000X better. You will never use a spray can again.
        If you keep the glue in the spray gun full it will stay just fine for several months between uses. Or, if you are like me and go through a gallon every month or two (I did 5 rear decks just like that over a 2 week period last month for example) you can use a gun until it is just a slimy nasty mess, like 2 years of more and just throw it away.
        If you have an air compressor, just do it. You will never again use a can.
        Great job, BTW. I should send you some top quality carpet. MUCH plusher and thicker, it has far more UV protection. The stuff at Parts Express is not really automotive grade.
        Maybe my boy Kevin will post the pics he got when we did his, I know he took a bunch.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • bmwman91
          • Oct 2004
          • 3133
          Thanks for the advice. I may look into that (I do have an air compressor).
          Yeah, I am a little worried that the parts express stuff isn't intended to handle the automotive environment. It had better not be faded after the first year or something!
          Does the nice stuff you use drape well? I passed up some thicker stuff because it seemed like it would be a nightmare to apply evenly.
          Kevin...is this THE E30 upholstery-guru Kevin? If so, my nice black micro-suede interior came from him. Top notch stuff!
          • george graves
            • 19996
            I'd love to see outdoor pics. The flash makes it really hard to judge.
            Originally posted by Matt-B
            • StereoInstaller1
              GAS
              • 22679
              I don't think you will be bad off in a year, but maybe 3 or 4 it will start to purple up.
              Did you get some decent scissors? I use an 8" Mondial, they are excellent and fairly cheap, about $40/pr.
              That material is actually headliner material with the foam backing peeled off...raging PITA to use, but was really pretty in this E34.
              The carpet I use is pretty pliant as it has no backing. There are 3 or 4 different products that have no backing though, but all will hold up OK on a rear deck.
              No, he is on R3V, I think his SN is Gerta (sp?). I do wish Kevin of Creative options was near me though...
              Closing SOON!
              • bmwman91
                • Oct 2004
                • 3133
                Haha well, I was using some rather crappy scissors. My fingers were killing me by the end...the upholstery blade was far more pleasant. I don't do this sort of thing often at all. I am amazed that this went as well as it did.
                I think I need an E34...awesome front kick panel space, a rear deck that looks like it could have magical possibilities for speakers, and probably more than enough trunk space for an equipment rack!
                • monty23psk
                  • Mar 2008
                  • 1289
                  I can tell you that Landau glue is awesome. Its what I am using on my interior door panels. Any local upholstery supplier will have it. I wished I had it for my rear shelf. Did it with micro suede but just used DAP contact cement. Worked out well though, just like trim adhevise, just had to brush it on.
                  Alex 88 m5 | 91 318is | 19 Subaru Ascent
                  BMW Tool Rentals & Fender Roller
                  • StereoInstaller1
                    GAS
                    • 22679
                    Let me tell you do NOT try and spray that contact cement! Oh my god, it makes spiderwebs of gluey crap 15 feet away, like HUGE mess!
                    Monty, what ya doin' with the panels? How about a thread and some pics?
                    I have a thread over on BF.c on E34 door panels about how I fixed a set.
                    Closing SOON!
                    • monty23psk
                      • Mar 2008
                      • 1289
                      Yeah, I can see that contact cement being a mess, so thats why I brushed it on. I got all my interior items from Kevin from Creative Options, great stuff. Here is a link to what I am doing (on the other e30 forum, and if it gets deleted, I will post the pics as I am working now and can't reach my photobucket account as it is blocked)
                      Here a link to the sound system set up I did in my trunk...
