Wet Floor
  • madman23
    • Jan 2007
    • 498
    Wet Floor
    Now i'm sure there are many threads on this but I couldnt really find one to explain my problem. My floor is wet on the passengers side right where you put your feet. I have checked my sunroof drain and they are clear. I have also checked the vent on the cowl under the wiper and thats good. HELP!!!
  • Winning
    • 39
    Read this thread, hope it helps
    • madman23
      • Jan 2007
      • 498
      Thanks man. appriciate it.
      • Winning
        • 39
        Anytime! Good luck!
        • benz-tech
          • Jan 2011
          • 382
          Hey man I just found one of my leaks. The water trailed down perfectly in the corner from the a/c hose grommet not getting the upper carpet foam wet at all and, of course, soaking the bottom
          I just posted it above:
          You say "Where are your other two cylinders?"
          I say "Where's your other camshaft?"
          Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
          • madman23
            • Jan 2007
            • 498
            So i looked into it and its actually because of my door being bent. Not that its not aligned on the hinges. The top piece is bent out a slight amount and its letting water in from random places. Thanks for the help.
            • 89DelphinE30
              • 287
              I have the same issue just haven't got around to fixing it yet :(
              • SimplyDope
                • 1335
                What would cause soaked carpet in a '91 3er coupe BEHIND the passenger front seat? It's dry in the front.
                • madman23
                  • Jan 2007
                  • 498
                  Sunroof gasket more than likely.
                  • SimplyDope
                    • 1335
                    Thanks for that, I know the seal is getting old so I'll take a look up there. It just comes from one side of it though and the car is parked flat, but I'll check it out.
                    • SimplyDope
                      • 1335
                      Well I noticed that with the passenger seat out, I can see the asphalt through one of the holes where the rear bolts goes through, which is where the mild leak was. Is there supposed to be a plug or something there?
