E30 m3 cluster for 24v swap?
  • dsobering47
    • Oct 2007
    • 697
    I'm struggling to find correct information regarding the E30 M3 cluster. I was wondering if it is possible to use that cluster with an E28 M5 coding plug for my OBD1 M52. My e30 is a 1991 318is, if that makes a difference.
    -Would the fuel gauge read incorrectly?
    -Would the tachometer be accurate?
    Any help is appreciated
  • mach schnell
    • Apr 2008
    • 1059
    Where do you get an E28 M5 coding plug from? Buy 'em new...? Part # ?
    • dsobering47
      • Oct 2007
      • 697
      bought new. p/n: 62111377664
      Real OEM is your friend
      • MattM
        • Apr 2009
        • 931
        you would need the right sensor to get the oil pressure working, ive looked into it, but the price of an M3 cluster is too much for the little gain you get from one
        Full Build Thread Here
        • dsobering47
          • Oct 2007
          • 697
          Dont care about oil pressure. Dont care about price.
          I want the 8k tach, OEM red needles, and "M" logo.
          Anybody have any success?
          • nmlss2006
            • 910
            ITYM temperature.
            • dsobering47
              • Oct 2007
              • 697
              Que? Like the coolant temperature? I already have the M20 single brown pin temp sensor...
              • Luis325
                • 3847
                interested in this as well, I have an m3 cluster and would like to use it in my swap...
                1986 "C2 2.7 Alpina" Sedan
                1987 325ic Black Vert
                  • 34839
                  -you can swap in your fuel gauge, but it depends what fuel level sensor the M3 came with, it might work out of the box.
                  -yes, with the M5 coding plug
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Some soldering will be required if you use the M5 coding plug. You remove the chip from it and solder it onto a regular E30 coding plug.
                    Use the E30 M3 oil temp sender for the correct oil temp, its easy to wire as well.
                    • kalib0y
                      • Dec 2004
                      • 3620
                      I am using an e30 M3 cluster and e30 325is coding plug (white) everything works for me but my RPMs do read about 500 higher than normal becuase the numbers on the tach face are clocked over a bit to go to 8k but the needle will sweep the same and read correct if I were to swap in a 325is tach which I am too lazy to do... oh an my oil temp isnt hooked up but I dont have a problem with that for now
                      95 7.1L 16V E36 M3
                      Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                      LIKE my Facebook Page! CLICK HERE
