mtech 2 wheel diamiter question
  • zerokid5555
    • 270
    How do you tell the diameter of your m tech 2 wheel? The wheel is 15" measured from the very outer edge - not sure if that's the correct way to do it. Comes out to 380 mm. Measuring from the "center" of the outer edge gets you 370mm.
  • acolella76
    • 2950
    easiest way is to measure is to take the part number, plug it into realOEM or bmwfans, and they do the math for you
    -Alex
    • zerokid5555
      • 270
      the only number found was on the back of the wheel hub 11528964 Nothing comes up on realoem or bmwfans which leads us to believe its the wheel hub part number.
      • zerokid5555
        • 270
        If there is a part number located on the wheel where is it? Or is there any other way to tell what wheel it is?
        • F34R
          sLaughter
          • 12376
          Remove the leather wrapping, it is under there.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • zerokid5555
            • 270
            Your saying the part number is stamped somewhere under the leather of the wheel itself? So you would have to ruin the leather to find the part number...?
            • reelizmpro
              • 9525
              It's stamped into the rubber (on the wheel itself) behind the horn pad. 086 is the small diameter 370mm M tech 2 wheel.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • zerokid5555
                • 270
                sweet! thanks man!
                • zerokid5555
                  • 270
                  So I am assuming the horn pad needs to come off correct? Sorry dont have the wheel in front of me
                  • acolella76
                    • 2950
                    well.. yeah to get behind the horn pad the horn bad has to come off lol :p
                    -Alex
                    • Nick_S
                      • Apr 2011
                      • 3655
                      What's the diameter of an airbag wheel in a late model? It feels gigantic to me and I want something smaller. Been looking at M-techs but if they're only slightly smaller I'd go aftermarket.
                      91 318is M50 swapped
                      05 Honda Pilot
                      24V swap thread
                      • davem
                        • Jun 2010
                        • 705
                        They're only slightly larger than the large diameter mtech wheels. They DO give an improved feel though...
                        • mik3*nw
                          • Apr 2009
                          • 87
                          so the small diameter wheel is 370mm? i was going to order one tonight but i wanted to make sure it was the smaller diameter one first.
                          • davem
                            • Jun 2010
                            • 705
                            yup 370 = small 380 = big
                            • reelizmpro
                              • 9525
                              I think the large is actually 385mm vs 370mm.
                              88 M3 - LACHSSILBER
