What to replace when replacing dash?
  • Landrunner
    • Aug 2011
    • 221
    I just got a brand new dash and plan on replacing my existing one in the next week or so. I have a small water leak right on the passenger's side of the tunnel; I've already cleaned the elephant trunk, etc...it is nothing bad but I want to address it when the dash is out. What kind of seals are behind the dash that lead to the outside that I should replace? Does anyone have a picture or a diagram that I could reference when ordering parts?
    Thanks in advance. :D
  • nrubenstein
    • 3148
    You'll want to replace the heater core sealing foam. If your wiper transmission needs replacing, do it - the only way to get it out is byb removing the heater box. You can do it from the front with a hammer, or unbolt it from the back.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Landrunner
      • Aug 2011
      • 221
      Thanks for the reply. Wiper transmission, meaning wiper motor? Does anyone have a p/n for the heater core foam?
      • gp.plus
        • 416
        I would put in a new heater core.
        • accident
          • 7303
          Originally posted by gp.plus
          i would put in a new heater core.
          +1
          Moral of this story?
          • davem
            • Jun 2010
            • 705
            My water valve started leaking before my heater core did so I replaced both. I would just leave the heater core stuff unless you have a non-ac car and the heater core is really hard to get access to without pulling the dash.
            • OnMy2ndE30
              • Sep 2011
              • 385
              When I find a dash to replace mine, I will be replacing the evap core, expansion valve, heater core and valve as well as what is listed above
              • Broom Broom
                • Jul 2011
                • 286
                im about to replace my dashboard in a month, i have a 1987 325e
                should i bother replacing any of these items listed?
                the heater core and wiper motor are they easy to replace?
                - 1987 325e m20 6cyl manual -
                • reelizmpro
                  • 9544
                  The only thing you should really change is the HVAC gasket if you can. It's nothing major but since the dash is out it's a good time to do it. Perhaps this is what Rubenstein meant by Heater core gasket? Heater core and valve can both be accessed with the dash in so it's not that big of a deal. Evaporator could be changed too if you still have AC. I actually replaced mine with a filter on my other M3 without AC. It's also a good time to wire in or fix the wiring on your aftermarket stereo/alarm. Doing it all in one shot.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Broom Broom
                    • Jul 2011
                    • 286
                    thankyou, yeah and my A/C is currently not working
                    • Landrunner
                      • Aug 2011
                      • 221
                      Perhaps the HVAC gasket is what could be leaking from the outside into my passenger's side tunnel area? Thanks for all the info so far.
                      • Landrunner
                        • Aug 2011
                        • 221
                        Anyone?
                        • reelizmpro
                          • 9544
                          The gasket I'm talking about is the thick foam gasket for the air vents only but there is a thin gasket between the HVAC and firewall. I doubt it's causing your problem though. What's leaking? coolant or water? The heater core could be leaking, HVAC drains could be missing or not installed right.
                          88 M3 - LACHSSILBER
                          • bernzpeed
                            • 3917
                            heater core is not that hard to access with dash on.
                            89 E30 S52
                            Transaction Feedback.
                            • nrubenstein
                              • 3148
                              The wiper motor is easy to replace from the front. The transmission is impossible. It's the assembly that the wipers bolt to.
                              As stated above, the heater core is really easy to replace with the dash in. In fact, I'm not sure that it's actually meaningfully easier to replace with the dash out, so I really don't understand why folks are so anxious to swap it.
