3 Spoke Airbag Wheel Swap??
  • m32go
    • 522
    I am looking to replace my ugly 4 spoke airbag wheel with a new one. I was going to do an MtechII wheel but thought I would like to keep an airbag. Has anyone either fit or seen the euro 3 spoke wheel with airbag in any of our cars? Thanks for the help.
    • 37833
    There's no Euro 3 spoke airbag steering wheel that i know of.
    Grover Beach, California
    BimmerHeads.com
    • m32go
      • 522
      If you search "3 spoke euro e36" on eBay there are a couple different ones listed. None show applications for an e30 though. I was just seeing if anyone had tried this yet or not. I am planning on doing one in alcantara for my e36 M3 to get rid of my ugly 4 spoke airbag wheel in that and just want to do the same in my e30.
      • davem
        • Jun 2010
        • 705
        the e36 ones won't fit onto the e30 column due to a different spline between the two cars
        • trackjunkie21
          • Jan 2010
          • 3962
          I remember seeing an uber rare e30 one, I just can't remember where.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • Cletonius
            • 2809
            I've been thinking that I'd like to swap to a newer 3-spoke airbag wheel also. Is there any of the newer steering columns that are a direct swap? Maybe I can just swap in a junkyard column with the wheel on it and wire it up?
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
            • einstein57
              • Jun 2007
              • 10780
              Cut and weld the spline portion? I would only attempt it if you knew exactly what you were doing. I'd try it if i wanted an airbag. I have a non airbag wheel that looks pretty similar to one. And know i'm not going to use a honda horn button.
              www.gecoils.com
              • m32go
                • 522
                With the spline swap brought up, will an E36 column, either tilt or not fit in an E30? There are a few tilt ones out there as I have one in my 95 M3. Would love to retrofit a tilt wheel in my E30 as well if it's possible.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  What model momo is that? Wasn't aware Honda wheels fit the e30.
                  • einstein57
                    • Jun 2007
                    • 10780
                    I could have sworn my sisters 85 fully loaded 325e sedan had steering wheel adjustment. I don't know if it was the weed though.
                    Civic Type R. MAD JDM YO!!! It does not bolt on with out some very creative mounting. From the factory momo used a hub adapter to mount it to the civics. Its not like the standard momo hub and it only uses 4 bolts. I bored out the spline section and drilled new holes to mount it to a thin quick release hub. That bolts up to any e30 hub adapter including nardi and grant. Here are some pics of it disassembled. http://honda-tech.com/showthread.php?t=1676987
                    www.gecoils.com
                    • willworkfore30s
                      • Aug 2011
                      • 1090
                      • willworkfore30s
                        • Aug 2011
                        • 1090
                        I know this doesn't match the 80's styling of the car, but I would love to have a fully functioning one of these in my car.
                        • m32go
                          • 522
                          Originally posted by willworkfore30s
                          That's the one I am going to put in my E36, but in Alcantara to match the rest of the interior.
                          I would also put it in my E30 if I could get it to work.
