Possibility of moving the seat up more than where it stops at?
  • Jrey
    • Nov 2011
    • 575
    as the title states, kinda curious to know if its possible to move the drivers seat up past more than where it stops it at
    is it possible or is there mods to be done?
    1986 325e (EUR)
    Grey Market
    Zinno
    327i Build
    Zender kit
    ESM 008TA
    Restoration progress TBA
    Originally posted by ethrtyiS
    sweet! day after my first final. really getting waffleswaffleswaffleswafflesed up then!!
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Yes, you'll need to make brackets to move the mounting points forward. I have had to do the exact opposite for me to fit into my e30s.
    • brent5631
      • Jun 2012
      • 421
      +1 need mine to be farther back. And a pushed back wheel too.
      • AndrewBird
        The Mad Scientist
        • 11898
        The only problem I see is being able to get to the front nuts to tighten them up. You best bet might be to just drill new holes through the floor and use a bolt and nut on the bottom. Or weld new nuts to the bottom of the chassis. If you do, make sure to plug up the original holes some how. A plastic plug and some sealant should do the trick.
        • JonnyOg
          • Sep 2012
          • 191
          Tell me exactly how you did it! I need more low.
          • jeffnhiscars
            • Jun 2011
            • 6011
            Seat tracks do vary and this is from a cabrio which I know has less movement than hardtops, but you can see the front and rear stops which are both held in with screws...or you can just cut them shorter in place.
            Alice the Time Capsule
