sport wheel in an airbag car troubles
  • dmjensen
    • Jan 2011
    • 805
    I bought a three spoke sport wheel ( not an mtech ) for my 92 vert that had an air bag wheel. when i installed the sport wheel i tried turning it and it snags on something. I can still turn it past whatever its hitting but its making a plastic popping noise... not sure if its hitting the plastic stud that is sticking out but I can't figure it out.
    I tried marking a few things with a sharpie to see whats hitting on. but i can't figure out whats going on. is this a common problem?
  • blefevre
    • Dec 2008
    • 4287
    You need to remove the white plastic pin that sticks out. It pulls right out.
    - E30, DSM, Golf R, Mazda 3 Skyactiv
    • dmjensen
      • Jan 2011
      • 805
      what's it do?
      • reelizmpro
        • 9556
        Pull the plastic peg out with pliers.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • dmjensen
          • Jan 2011
          • 805
          do tell? will it release magical creatures from my e30 and make it do amazing wheelies?
          • blefevre
            • Dec 2008
            • 4287
            The white pin is only used for airbag wheels and a non-airbag wheel will bind up with it in place. I think it is used to engage the airbag, but that's just a guess. Make sure you also have a spacer in place. Search around, it's been done millions of times.
            • dmjensen
              • Jan 2011
              • 805
              thank you sir's, I'm a little disappointed that the peg was only for the clock spring and not magical creatures though.
