E30 carpet types/differences
  • Kozworth
    • May 2011
    • 1339
    I know the vert carpet is narrower then coupe to accommodate for the narrower rear portion, also the reason why verts have a different rear seat.
    Is there any difference between the coupe and sedan? Also I didn't really look at my carpet but does it literally go under the hvac panel and have to remove that to get the carpet out?
    Thanks
  • Murtosa
    • Apr 2013
    • 45
    i have a vert so im not sure if its the same but ive never heard of anyone haveing to remove the HVAC but i could be wrong
    • Kozworth
      • May 2011
      • 1339
      It looks like its completely underneath the hvac panel, could be wrong though. Any input on the differences in coupe/sedan carpet if any?
        I believe the coupe and sedan carpets are the same. And to fully change a carpet the dash and then the HVAC assembly will have to be removed.
        • Todd Black 88
          • Oct 2007
          • 3449
          Most just cut around the hvac box and remove the carpet. It's all hidden when the consoles are back in.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • Kozworth
            • May 2011
            • 1339
            Yea that's what I am going to do I don't have the time to remove the dash so much to do so little time
            • mikeedler
              • 6707
              they are not the same the B pillar area is different due to the doors being shorter in the front on a 4 door. I think it might be possible to put a 4 door carpet in a 2 door, but not so much the other way, without there being a not so nice looking areawhere the B pillr is on the 4 door.
              • bernzpeed
                • 3917
                the carpet are made of 2 pieces. the sedan and coupe vary through the small second piece that goes underneath the rear seats. you will see the difference in the corners because coupe seats are square at the corner and does not require to be covered while the 4 door sedan is rounded and thus shows when you open the door.
                Ps, the part where the shifter goes, manual cars is completely covered with carpet while autos have that rectangular piece missing
                89 E30 S52
                Transaction Feedback.
                • robrez
                  • Jul 2008
                  • 3376
                  ^^^ This person speaks the truth. The only difference between the coupe and sedan carpet is the rear piece, which is shaped differently because coupes and sedans have differently shaped rear bottom seats. The sedan seats are rounded at the edges to make it easier for passengers to enter.
                  January 2012 COTM
                  • 3vilE30
                    • Jan 2013
                    • 344
                    Don't forget the sound deadening/insulation if I'm correct early models have separate insulation from the carpet there not bonded together. On my 88 super eta when I was ripping out the carpet the insulation was bonded with the carpet I think the early model insulation is lighter as well? Just cut around the heater core and you'll be good can't see the cuts because the top center console covers it.
                    • cmcgrogan
                      • May 2013
                      • 240
                      sort of bumping an older thread, but are all coupes the same, regardless of the model? i have a 325is, and found a carpet out of a 318. i am assuming it will work, but do not want to be stuck with a carpet that wont work
                      Originally Posted by scaraveos
                      Are saying about welding the head to the block? and if yes how is it seperated if required?
                      (possibly a stupid post)
                      • Kozworth
                        • May 2011
                        • 1339
                        anything but a vert carpet works in any e30 (not sure about touring) is what I gathered from this thread.
                        • Northern
                          • 5040
                          My '87 iX had separate carpet and foam, but my '90 and '88 have the one piece carpet/foam.
                          Originally posted by priapism
                          Originally posted by shameson
                          • Link
                            • May 2012
                            • 834
                            BUMP again, how is this so confusing? There has to be someone with first hand experience who can answer this.. will a coupe late model carpet set work in a late model sedan?
                            View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                            • Link
                              • May 2012
                              • 834
                              I just bought a e30 COUPE CARPET and installed it into my SEDAN. The front large piece fits PERFECT. The rear smaller piece fits good, but the corners near the door are different. BUt still works very well!
