Seats that give more head room?
  • Scott314
    • Jan 2005
    • 287
    #31
    Originally posted by Beej '86 325es
    my thought as well. No, that's not a bad idea, it's my plan as well actually. If you don't have a roll bar, you shouldn't be running 4, 5 or 6 pt harnesses.
    Most fixed back seats that I've seen look like they're made for harnesses, so I wasn't sure. I've seen quite a few driving instructors with 3 or 4 point Schroth harnesses and stock seats with no roll bar. Personally, I'd rather have a more supportive seat with a stock belt than the other way around, but I don't think there's anything wrong with the way they do it.
    My fast says: traction control is for the faint of heart :evil:
    • rwh11385
      lance_entities
      • 18403
      #32
      I do. Shitty seats + harnesses suck in comparison to a highly bolstered seat and a cg lock.
      fixed back seats + no rollbar = FTL as well
      • Scott314
        • Jan 2005
        • 287
        #33
        That's what I thought...Reclining street seat FTW.
        I didn't get a chance to compare supportive seats + stock belts to 4 pt. + stock seats.
        • jht3
          • 288
          #34
          i recently switched from my m3 seat to a recaro srd mounted to really old height adjustable sliders and the new low wedge bracket. with the high bracket i was sitting higher than the low setting on my stock seat. now with the low bracket i am a little lower than the low stock setting, but i would like it even lower. unfortunately i can't do that without another bracket or ditching the sliders. the wedge bracket retains the stock belts
          with a helmet on, i have room, but not much
          i'd like to see some pics of this super low setup rob has
          James
          '88 M3
          • Scott314
            • Jan 2005
            • 287
            #35
            Take a look at his sig. Us 6ft.+ guys have room even with helmets on. I want something as low as his.
            • rwh11385
              lance_entities
              • 18403
              #36
              He might mean Rob Case?
              Basically, you know where the floor is raised and has those vents? Put two metal beams across that, bolt a seat to it, and have had two bars welded perpendicular to those beams that are on the floor to be bolted down.
              If not: My setup is only marginally lower than yours. I have your setup on my passenger side and could measure the difference.
              • jht3
                • 288
                #37
                someone said rob has a seat that makes 6 footers look like children. i have no idea who rob is but the mounting sounds great
                i've thought about welding up my own bracket to get my bottom-mount recaro as close to the floor as possible, but the amount of work vs the extra room gained doesn't like its worth it. i need to retain the stock seatbelts so that adds to the complexity. i'm happy with the way i'm currently setup.
                James
                '88 M3
                • Charlie
                  kid tested, administrator approved
                  • 6686
                  #38
                  Rob, aka "Skafrog".
                  I'm no bohemoth at 5'6, but you can see what I look like in the seat. It's barely a "bracket", and more a peice of metal holding the seat bolts to the floor.
                  -Charlie
                  Swing wild, brake later, don't apologize.
                  '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                  FYYFF
                  • rwh11385
                    lance_entities
                    • 18403
                    #39
                    Charle needs the budget beater phonebook mod
                    • ColdAccord
                      • 5926
                      #40
                      Originally posted by Charlie
                      Rob, aka "Skafrog".
                      -Charlie
                      hahahahahaha
                      Originally posted by blunt
                      • Scott314
                        • Jan 2005
                        • 287
                        #41
                        Rob, aka "Skafrog".
                        -Charlie
                        Hey Charlie, you just pulled the drivers side sport seat out of your car right? Do you still have that lying around?
