AM gauges...who's using what?
  • 968Reckless
    • May 2013
    • 1095
    Looking to install a few after market gauges, possibly in the front ashtray area. Curious to see what brands everyone is using/what matches the interior the best as there are so many out there. Let's see some pics!
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
  • pandaboo911
    • 2070
    I'm not using them but good old fashioned VDO gauges match the 80s interior well.
    Like this
    • Codym42
      • Mar 2013
      • 611
      I'm using VDO vision gauges with the panel that is sold here on r3v. They're a tight fit and you have to use the stud mounting kit. Other than that, they match the interior quite well. They even light up red at night.
      '90 325i - 5 speed coupe
      '05 330ci 6MT ZHP
      • Dj Buttchug
        • Jun 2010
        • 7688
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • 968Reckless
          • May 2013
          • 1095
          I currently have a vdo in my DD and it works great but I want to change it up and get something different
          /// MTech Belts ///
          S52 BUILD
          M3 VERT BUILD
          • ak-
            • 12422
            Vdo oil temp, oil pressure, boost, water temp.
            The only thing digital is the AFR gauge. Vdo matches real well in our interior - timeless
            1991 325iS turbo
            • BlackSpeed66
              • Apr 2008
              • 624
              I've got the VDO vision series as well in my car. Hoping to add a few more gauges once the swap is done!
              -Geno
              '87 325is (s52'd)
              '95 525iT
              '95 Jaguar XJR-6
              '02 Range Rover 4.6 HSE
              '98 Disco 1
              • mitchlikesbikes
                • Dec 2013
                • 858
                I have VDO gauges in a triple dash vent pod. voltage, oil temp, oil pressure. they were pretty cheap and i'm very happy with them.
                not the best picture:
                IG: @mitchlikesbikes
                • 968Reckless
                  • May 2013
                  • 1095
                  Is your dash wrapped?
                  /// MTech Belts ///
                  S52 BUILD
                  M3 VERT BUILD
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    I'm using vdo gauges as well. They are the one from bmp designs.
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      it's flocked
                      • Shaffer325ix
                        • Nov 2014
                        • 37
                        I have always liked Autometer. Good selection of both style and function.. I'm working on the 4 gauge set-up in the vent. 2 Pyro's, A/F wideband, Fuel pressure. Good for diagnostics , especially if you're boosted.
                        1991 325ix
                        My 325ix Build
