Seat Bolt Question Newer Sport Seat in Older E30
  • Petebee
    • Jan 2008
    • 267
    Okay so I am trying to find a bolt that holds down the rear of the seat rail of my newer vintage E30 sports seats in my older vintage 1985 325e. I tried to both an M10x1.25 40 and M10x1.5 40 sized metric bolt but neither work.
    Bolts that fit standard older sports seats use an M10x25-Z3 bolt, which I have (essentially a 25MM M10 bolt with a very unique thread pitch). Problem is they are too short for the later style seat rails, which are thicker and won't allow the bolt to thread into the unibody.
    Can I just use an M10x32 bolt that RealOEM displays for use in later E30s? I assume these have the unique thread pitch that I am looking for.
    Right now I have been able to secure three of the mounting nuts on the studs for the the drivers seat, but I can't get the rear nut secured on the passengers side. I am not comfortable driving around like that...figure if I can get the rear bolts installed that should pull the rear of the passengers seat down so I can also attach the nut on the stud in addition to the bolt.
  • yngtmr
    • Mar 2016
    • 88
    minor thread revival, but I'm going through the same problem right now, where did you source the new studs from? do you have the part numbers? any help would be very appreciated
    84 325e, Saphirblau Metallic/Houndstooth Sport, OBD-2 M52B28/ zf320
    • Downeaster1
      • Mar 2008
      • 85
      Also bump. I have the same problem.
      1985 325e Sedan, 1986 325e Sedan, 2006 BMW X5, 2012 M3 Sedan, 2013 135is, 2017 M3 Sedan ZCP Competition
      • jeffnhiscars
        • Jun 2011
        • 6010
        Ive never encountered any thread issues with seat mounting bolts or nuts. However the rails on early cars have a different depth so bolt lengths vary. My guess is that the threads need some love.
        Alice the Time Capsule
        • uturn
          • Dec 2010
          • 1001
          Be sure to get the right length bolts because if too long they will rub the fuel lines under the car.
          • Downeaster1
            • Mar 2008
            • 85
            Can you access the bolts from under the car? I'm somewhat new to E30's.
            • roguetoaster
              Biggus Tippus
              • 7830
              Yes, easiest way to find them is to take the bolts out, light the cabin, or put something longer through the holes and look under the car. However, just looking under the car is cool too.
              • Michael216
                • Jan 2019
                • 1
                Underside bolts
                Are the bolts that come up from the bottom of the chassis that are for the seat frames welded into the car? I'm not sure how I should go about in replacing them for longer ones. I have comfort seats out of an 88 325 that have a thicker frame. Any help would be awesome.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  They are studs welded to the body. You would need to weld new ones on if you wanted to replaced them.
